CB Radio
Pig
Loads of cheap good rigs on ebay.
If you find one you like i will let you know if its any goood.
Something like a superstar will be reliable http://cgi.ebay.co.uk/superstar360-converted-to-10m_W0QQitemZ280447072475QQcmdZViewItemQQptZUK_ConsumerElectronics_SpecialistRadioEquipment_SM?hash=item414bf2b8db and you will have more than enough channels to play with plus the added use of usb/lsb if you know how to use it.
or go for a midland 38 or 98 for plug and play.
What sort of range are you hoping for?
And yes im one of those radio nerds and have been since i was a kid :-(
1. Do I need a licence? Yes, you should really, if only because if people don't buy them then HMG may assume that CB is getting less popular and take the frequency away. They cost £15 a year and are no longer available from the Post Office. Instead you need to write to: The Radio Licensing Centre, SSL, PO Box 884, BRISTOL, BS99 5LF.
ive got a set up you can borrow ill dig it out check it still works first i use to use it for off roading but its been in the garage for a cpl of yrs
Yes please, that would be fantastic! Seeing as i only need it for 4 days im loathed to spend 75 on a setup.
Thanks
Jon
