Digsy Posted January 7, 2010 Share Posted January 7, 2010 I've just got my 1TB NAS up and running. I'm completely new to this kind of thing. I think I've got it working, but I wanted to check with the more techy types that there isn't something basic I've missed. My NAS has a single volume on it which sometimes appears to be called "C" or "VOLUME". I'm not sure if you can create more than one volume or rename the current one, but I have just accepted the default. I have created two shares within this volume called "My_Documents" and "My_Media". These are mapped to drive letters Z: and M: respectively within Windows Explorer. I am the only user on my PC so I have created both shares with public access. The odd thing is that when I first mapped them to the drive letters Windows still asked me for a username and password. I typed in the NAS admin username and password and it seemed happy, but I'm unsure why it needed these to access a public share? Eventually, I will set up individual user accounts, with home areas and the like. It isn't mentioned in the manual anywhere, but I assume that I would create a user profile in Windows, activate having to type in a username and password to log into Windows, and then create identically named accounts on the NAS? Link to comment Share on other sites More sharing options...
JustGav Posted January 7, 2010 Share Posted January 7, 2010 Which brand of NAS? Also even with public shares it still uses a username even if it is just 'guest'. As you have said, your best approach is to create a username on the NAS identical to your windows username and use that. Remember a NAS isn't like a USB hard drive, it is designed for multi user access hence has authentication. Link to comment Share on other sites More sharing options...
Digsy Posted January 7, 2010 Author Share Posted January 7, 2010 It’s a Netgear ReadyNAS Duo with 2x 1TB drives installed (RAIDed). So when I mapped the public shares to network drives, I could have used any username at all, and left the password field blank and it would still have connected? I'll try that (if I ever get home again!). Yeah, I know that using NAS is a load more complex than a local drive. Previously I have used two local drives (not RAIDed) and a backup script to copy important files between the two. However, I'm about to set up media-streaming around the house to it seemed like a good idea to move to centralised storage for everything. At the moment, though, I don't really need to control user access becaue I'm the only user. Another thing I've noticed is that when I'm logged into the NAS as admin using its web interface I can see the shares I create instantly. However it can take several minutes for them to be available to map to a drive through Windows Explorer. Is this normal? Link to comment Share on other sites More sharing options...
