Duffman Posted January 5, 2010 Share Posted January 5, 2010 Done a few searches and can't find much info on this...i'm going to have to remove the drivers side mirror from my Supra as someone kicked it in half. Is there a how to guide on here or can anyone point me in the right direction as to where the bolts are hoding it on? Also may have to remove the passenger side assembly even though this isn't broken they have only removed the glass from this but looks like they may have ripped the wires out in the process. Any help appreciated Quote Link to comment Share on other sites More sharing options...
Nic Posted January 5, 2010 Share Posted January 5, 2010 You will need to remove the door cards first, see Si's how to guide HERE. There are then 2 nuts holding the wing mirror on, they are a little fiddly to access, but you should be able to feel your way, you will also need to disconnect the plug for the wiring. Quote Link to comment Share on other sites More sharing options...
Duffman Posted January 6, 2010 Author Share Posted January 6, 2010 You will need to remove the door cards first, see Si's how to guide HERE. There are then 2 nuts holding the wing mirror on, they are a little fiddly to access, but you should be able to feel your way, you will also need to disconnect the plug for the wiring. Thanks for that Quote Link to comment Share on other sites More sharing options...
