Turbo conversion on a N/A auto
rosscod22
I have decided to look into doing a turbo conversion on my j-spec N/A auto. Has anybody had any experience in this before? I mainly want to know how much it is likely to cost and obviously where to look for getting reliable parts? and Are there any garages or workshops you would recommend to do the work?
I'd appreciate any advice you could offer.
:thumbs:
From what I have gathered from people who have TT's, it costs roughly £10,000. This figure will be slightly more if you have a NA Auto as you will need TT engine and also manual conversion with a 6 Speed I believe to hold the power of the single (Unless it is a small single then a 5 Speed should be fine).
Edit: Ops ignore the above unless you was thinking Single Turbo, when you said turbo conversion I was thinking single! :D
Edited by Abz (see edit history)
This question has been done to death, discussed at lemgth, then bisected the perpendicular, to come to the same conclusion..............
a money pit which will take ages to do properly, to get, at best, stock TT hp. There are a couple of mad money builds on supraforums, but the concensus on here is forget it.
Best route is a TT conversion, done in a few days, with a TT autobox, around £2600 fitted and warranted.
Probably not what you want to hear, but imo, the only sensible way of upping an NA's performance for relatively little outlay. What about selling, then buying a TT?
