paulj1 Posted January 4, 2010 Share Posted January 4, 2010 Hi does any one know if blue print do the top rear susspension arms for a j spec tt? as the toyota ones from dealer are just stupidly over priced Thanks Paul Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 4, 2010 Share Posted January 4, 2010 No one but Toyota makes them. Considering they are forged alloy with two rubber mounted spherical bearings in them and a ball joint they are pretty reasonably priced. Believe me, far worse things can need replacing, they are still available, easy to get, and easy to fit Quote Link to comment Share on other sites More sharing options...
paulj1 Posted January 4, 2010 Author Share Posted January 4, 2010 thank you Chris i think i will try a different dealer as our Hull one isn't the best Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 4, 2010 Share Posted January 4, 2010 I keep them in stock and I'm cheaper than Toyota by a fair bit....I also keep them in stock with poly bushes now as well. 0208 3671286 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 4, 2010 Share Posted January 4, 2010 Paul Whiffin sometimes has good prices on some new suspension arms, worth a call. Whifbitz in the traders section. I think I still have some good used ones, but it's not a good idea fitting used suspension stuff really. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 4, 2010 Share Posted January 4, 2010 try keron if your on a tight buget , hes well priced on use parts, you can then have them polybushed Quote Link to comment Share on other sites More sharing options...
