power steering reservoir top hose replacement - help!
fastnfurious
i've replaced the bottom hose (which links to the power steering pump) on the power steering reservoir but according to Toyota, the top hose comes together with the cooling rod which i don't see the need to replace them + costs much more! is it possible to replace just the rubber section for the top hose and what's the measurement like ie. hose OD/ID and type of hose? thanks!
cheers, Michael (UK-spec Supra TT auto)
Guest blownminiturbo
i used braid but you should be able to get power steering/oil hose that size from a hose specialist who do truck hydraulics and stuff
