Supradk Posted January 3, 2010 Share Posted January 3, 2010 hi guys how wide are new uk 330mm brake disc in mm? front! How wide are they when you should replace them? already tried to look on the forum but i dont find anything:( Anyone know about rear disc? regards kåre Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted January 3, 2010 Share Posted January 3, 2010 (edited) Alright fella, I think they should be 30 mm thick for new disks, recommended mimimum is something like 28mm I think. The rears min are 15mm IIRC. Edited January 3, 2010 by T2 MSW (see edit history) Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 3, 2010 Share Posted January 3, 2010 (edited) If you bare referring to the thickness of the disc, the minimum is stamped into the edge of the disc. Fronts minimum is 30 mm. New is 32mm. Rears new 16mm, minimum 15mm Edited January 3, 2010 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted January 3, 2010 Share Posted January 3, 2010 Ah learn something new every day, did not know they stamp the minimum into the edge of the disk Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 3, 2010 Share Posted January 3, 2010 Oopps it is stamped on the bell on the rears. You may need to wire brush the bell to read it. Quote Link to comment Share on other sites More sharing options...
Supradk Posted January 3, 2010 Author Share Posted January 3, 2010 thanks guys :-) Quote Link to comment Share on other sites More sharing options...
Rinus Posted January 3, 2010 Share Posted January 3, 2010 330mm? these are 323 front and 324 on the rear for uk-spec or am I mistaking... Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 3, 2010 Share Posted January 3, 2010 330mm? these are 323 front and 324 on the rear for uk-spec or am I mistaking... No you are correct, 323 & 324 Quote Link to comment Share on other sites More sharing options...
