ajazyasin Posted January 4, 2010 Share Posted January 4, 2010 be careful buying a cheap uncared for soarer. Chances are, the turbos are going/gone and the engine has been thrashed within an inch of its life. Buy the soarer with the intention of using the engine and not the turbos and you wont be disappointed. Quote Link to comment Share on other sites More sharing options...
Lude Posted January 6, 2010 Share Posted January 6, 2010 be careful buying a cheap uncared for soarer. Chances are, the turbos are going/gone and the engine has been thrashed within an inch of its life. Buy the soarer with the intention of using the engine and not the turbos and you wont be disappointed. i wouldnt say that soarers are driven very hard, tbh they are not very sporty cars at all standard. all brown & automatic interior, mature drivers car id say. http://www.autotrader.co.uk/classified/advert/200953349282836/sort/priceasc/usedcars/make/lexus/model/soarer/radius/1500/page/1/postcode/cf434ht?previous=%2Fsearch%2Fresults%2Fusedcars%2Fpostcode%2Fcf434ht%2Fradius%2F1500%2Fmake%2Flexus%2Fmodel%2Fsoarer%2Fsort%2Fpriceasc%2Fpage%2F1&logcode=p (obv the manual drifty ones different) but standard id say their ok there much work/parts using the R154? bellhousing, clutch and master/slave cylinder, pedal, that it? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 7, 2010 Share Posted January 7, 2010 I dunno, Ive abused previous Soarers in my past, '150+mph on a closed test track'... Prop shaft, wiring, the pedals come as a pair so its brake and clutch pedals. Youll need to drill holes in the bulkhead too Quote Link to comment Share on other sites More sharing options...
ray007 Posted January 15, 2010 Author Share Posted January 15, 2010 (edited) one more question for jay and others, If i use a soarer autobox replacing a supra auto box is there any complications? i.e size, fitting, gearstick, selecting gears etc? Edited January 16, 2010 by ray007 (see edit history) Quote Link to comment Share on other sites More sharing options...
ray007 Posted January 16, 2010 Author Share Posted January 16, 2010 any1? Quote Link to comment Share on other sites More sharing options...
Jay_vr6 Posted January 16, 2010 Share Posted January 16, 2010 sorry buddy I have no idea on the autobox side of things, would a TT autobox not be easier ?? Quote Link to comment Share on other sites More sharing options...
garethr Posted January 16, 2010 Share Posted January 16, 2010 I believe the Supra auto is different from the Soarer auto - electronic line pressure control vs cable line pressure control, so you would need the Soarer 'box with the Soarer ECU. Quote Link to comment Share on other sites More sharing options...
ray007 Posted January 17, 2010 Author Share Posted January 17, 2010 I believe the Supra auto is different from the Soarer auto - electronic line pressure control vs cable line pressure control, so you would need the Soarer 'box with the Soarer ECU. im picking up a complete soarer auto 2.5tt. i have an na auto and a 5speed manual to play around with, so im thinking since im getting the soarer auto box and ecu and everything else it would make sense to do the conversion to the auto sup? still cant make my mind up, im picking up the soarer on saturday. Quote Link to comment Share on other sites More sharing options...
garethr Posted January 17, 2010 Share Posted January 17, 2010 If it was me, I'd go with the 5-speed. There are plenty of 1JZ (and 1UZ) conversions running the W58 in the USA and Australia. Quote Link to comment Share on other sites More sharing options...
JDM Power Posted August 9, 2011 Share Posted August 9, 2011 already did the swap here we go Quote Link to comment Share on other sites More sharing options...
David P Posted August 9, 2011 Share Posted August 9, 2011 (edited) You could use a T.T./Soarer auto box and T.C. for strength, swap in N/A valve bodies and control it with a Suprastick for manualised gear changes. Plenty of info how-to in the transmission section in link below. Edited August 9, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Jay_vr6 Posted August 9, 2011 Share Posted August 9, 2011 1jz superthread revival Loads of 1jz supras about now Quote Link to comment Share on other sites More sharing options...
ray007 Posted August 9, 2011 Author Share Posted August 9, 2011 thanks for your imput guys but i finished this converison over a year ago Quote Link to comment Share on other sites More sharing options...
