DC's Promotional Supra
Callaway Motorsport
Thought it was about time to make a proper project page on here.
Since me posting in the new members section, having repaired the car and have it resprayed. a few things have been done and purchased.
Having an own company in the Netherlands now for a year, 2010 will be important for us to promote alot over on the continent.
Exterior wise the car will be staying stock as far as rear bumper etc go, I still have a ridox replica front bumper which probably will go on for the summer.
We are aiming at having not too much show, but more of a quality and proffessional engineering car to show off, and that is one of the reasons it will stay stock body as much as possible.
Enough talk. Here is the car as i purchased it:
http://lh6.ggpht.com/_mZNTX4tRdck/Sz5wKz8QRxI/AAAAAAAACQg/IFv3qij8J1k/s720/T04R%20Supra%20%2838%29.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5wLPCGJoI/AAAAAAAACQk/jYedpFci21M/T04R%20Supra%20%28148%29.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5wLQM1WKI/AAAAAAAACQo/PIx365UpsJ8/T04R%20Supra%20%28223%29.jpg
http://lh4.ggpht.com/_mZNTX4tRdck/Sz5wLtF7o1I/AAAAAAAACQs/gP-tltgqOg4/T04R%20Supra%20%28232%29.jpg
Spec sheet when purchased:
2JZ 3000cc RZ Engine
HKS T04R Turbo :
Garrett T67 (T04R)
Good for around 600+hp
Journal Bearing
T4 style inlet flange with 2.5" V-band exit, A/R: 1.00
HKS Manifold
HKS Wastegate with screamerpipe.
HKS Induction Filter
HKS M40I Super Fire Racing Plugs
Aftermarket Hi Lift Cams
Metal Suction Pipe
Oil Cooler and Oil Filter Relocation Kit
Aftermarket Front Pipe
Titanium Exhaust System
Air Intake Funnel
Large Blitz Front Mounted Intercooler Kit
Trust Racing Blow Off Valve
Aftermarket Injectors (Red)
ARC Rad Cap
Clear Front Winkers
Tanabe Sustec Front Strut Brace
Polished Cam Covers
SUSPENSION / BRAKES / WHEELS / DRIVE
Getrag 6 Speed RZ Transmission
Multi Plate Clutch
2 Piece Front Slotted Rotors
Aftermarket Brake Pads
CST Zero-1 Coilovers
Rear Stainmesh Brake Lines
18" Work Emotion CR Kai Alloys
Large RZ Spec Calipers
Lightweight Wheel Nuts
Aftermarket Rear Slotted Rotors
BODY / EXTERIOR
Late Model Headlights (HID)
FRP Vented Bonnet
Top Secret Front Aero
Top Secret Side Skirts
Top Secret Rear Canards
Front FRP Wide Fenders (Ridox)
Rear Fenders Folded for Clearance
Rooftip Spoiler
INTERIOR
Momo Concept Steering Wheel
Blitz ID Power Meter
Blitz Sequential ID Boost Controller
Bride Drivers Bucket Seat
Aftermarket Shift Knob
Aftermarket Handbrake Button
Apexi Turbo Timer
Sony Xplod Audio Unit
Razo Pedals
Greddy Electronic Boost Gauge
Greddy Oil Pressure Gauge
Greddy Temp Gauge
Blitz Temp Gauge
Omori EGT Meter
As you can see, the engine left me with quite a bit of work on cleaning the wiring up and making it all a bit more reliable.
Once the vehicle was back here, we gave it a good check over and went through some items to see what we had to change/remove/replace along the way.
The japanese 'spaghetti' wiring was my most ennoying experience,
the car had a Blitz ID3 BC and power meter, along with some other oldish gauges. But in order to get the power meter to work they would use the same sensors as some of the gauges installed. Now what the previous owner had done is not use a secondary wire, no.....
They cut and rewired the sensors to the power meter and left the gauges not working. This was a real pain in the arse and I wanted to sort it quickly.
However, my only solution and choice to sort it now is to strip it all out, and install all new, with in return is a good choice anyway for a promotional vehicle.
http://lh3.ggpht.com/_mZNTX4tRdck/Sz5xdjiepcI/AAAAAAAACSk/-kDcp3n8BSE/s720/DSC07172.JPG
Rusty screamer (to be replaced by SS in the coming few months)
http://lh4.ggpht.com/_mZNTX4tRdck/Sz5xd7pGH9I/AAAAAAAACSo/sOgka4MFlPo/s720/DSC07175.JPG
http://lh6.ggpht.com/_mZNTX4tRdck/Sz5xeKYD6pI/AAAAAAAACSs/23i7EmUP0Ew/s720/DSC07176.JPG
http://lh3.ggpht.com/_mZNTX4tRdck/Sz5xe9GlfqI/AAAAAAAACS0/T8D4nQGE1HU/s720/DSC07577.JPG
The oil relocation kit was in a crappy place for servicing.
This is still an ongoing project to get it up behind the passenger/driver side headlight and the oil cooler will replace the filter in this same position.
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5xfMROg-I/AAAAAAAACS4/ucf0F3JNVzo/s720/DSC07578.JPG
Edited by Callaway Motorsport (see edit history)
  • Replies 66
Some parts which came in in early 2009.
Bride seats, carbon Stradia low max with RO rails (ultra low) and Sabelt FIA harnesses
http://lh3.ggpht.com/_mZNTX4tRdck/Sz59LjmeopI/AAAAAAAACUM/695WBJ8qOzI/s576/DSC05708.JPG
http://lh4.ggpht.com/_mZNTX4tRdck/Sz59M9POfVI/AAAAAAAACUU/pJKtaWFN_qY/s576/DSC05710.JPG
TRD Gauges
http://lh5.ggpht.com/_mZNTX4tRdck/Sz59REw2kMI/AAAAAAAACVU/866TKcpWSsc/s720/DSC07807.JPG
Fcon-Vpro (not the latest as that was released just after i purchased)
http://lh5.ggpht.com/_mZNTX4tRdck/Sz59NSKNUNI/AAAAAAAACUc/XvsSw9F7RDY/s720/DSC06605.JPG
This might be replaced next year by AEM V2 or Solaris, not sure which yet.
Ridox boot spoiler (might not put it on in the end, need to test fit and look soon)
http://lh3.ggpht.com/_mZNTX4tRdck/Sz59N0GR1sI/AAAAAAAACUk/8jCA7nBb4Mk/s720/DSC07016.JPG
TRD Front strut (also to be powdercoated soon.)
http://lh4.ggpht.com/_mZNTX4tRdck/Sz59ODZVy_I/AAAAAAAACUo/9OT0kWuZpe4/s720/DSC07033.JPG
Carbon radiator cover:
http://lh5.ggpht.com/_mZNTX4tRdck/Sz59O4GXGFI/AAAAAAAACUw/X2hPFvH5D4Y/s720/Kopie%20van%20DSC07041.JPG
Turbo jacket for the cold winter ;)
http://lh5.ggpht.com/_mZNTX4tRdck/Sz59Pbb9jMI/AAAAAAAACU4/X0PHC8ze8Zw/s720/DSC07051.JPG
Tial 50mm (might be replaced soon by latest version)
http://lh6.ggpht.com/_mZNTX4tRdck/Sz59Poj5llI/AAAAAAAACU8/rNeExqVLBII/s720/DSC07058.JPG
Some hoses for various bits (most large fittings will be replaced by braided versions)
http://lh6.ggpht.com/_mZNTX4tRdck/Sz59QCqPmlI/AAAAAAAACVE/f96SR_rQQIw/s720/DSC07062.JPG
C-West rear light covers
http://lh4.ggpht.com/_mZNTX4tRdck/Sz59ReVso4I/AAAAAAAACVY/4FdXiAm5j2E/s720/DSC08342.jpg
Then some powdercoating
http://lh6.ggpht.com/_mZNTX4tRdck/Sz5w2ogtc4I/AAAAAAAACRg/V0jRACj-lZw/s720/DSC08228.jpg
http://lh3.ggpht.com/_mZNTX4tRdck/Sz5w24dpeaI/AAAAAAAACRo/QS8DKhxkBBw/s720/DSC08225.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5w3N1CV4I/AAAAAAAACRs/XVDqlwui5rc/s720/DSC08221.jpg
http://lh4.ggpht.com/_mZNTX4tRdck/Sz5w3jZraLI/AAAAAAAACRw/OGNMMWY-gJw/s720/DSC08219.jpg
http://lh6.ggpht.com/_mZNTX4tRdck/Sz5w4AWzqKI/AAAAAAAACR0/hRMxaf6sRQo/s576/DSC08218.jpg
Some DIY Spraying:
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5w0-I3U6I/AAAAAAAACRI/YZmG3lPDyJY/s720/DSC08078.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5w1GY21KI/AAAAAAAACRM/ZblkSMM_2pA/s720/DSC08082.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5w1QNB4dI/AAAAAAAACRQ/YdZMYh-P2gk/s720/DSC08083.JPG
http://lh4.ggpht.com/_mZNTX4tRdck/Sz5w17jScgI/AAAAAAAACRU/Fj5fw401HPw/s720/DSC08087.JPG
http://lh3.ggpht.com/_mZNTX4tRdck/Sz5w2BDUCwI/AAAAAAAACRY/f4FvQ6rT-xk/s720/DSC08089.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5w2f6VMjI/AAAAAAAACRc/BcBwcQUPeEg/s720/DSC08096.JPG
Next was the cleaning up.
I decided to clean and respray most to all the whole bottom of the car including axles etc. To make the whole thing neat again.
http://lh5.ggpht.com/_mZNTX4tRdck/Sz53Ls5ol6I/AAAAAAAACTc/bPxhBUP524s/s720/DSC07180.JPG
http://lh3.ggpht.com/_mZNTX4tRdck/Sz53MH8sBlI/AAAAAAAACTk/YsVBtwX3hx0/s720/DSC07195.JPG
Respray taking place:
http://lh3.ggpht.com/_mZNTX4tRdck/Sz53NiLWUJI/AAAAAAAACTw/031pZh3_j0s/s720/DSC07538.JPG
http://lh4.ggpht.com/_mZNTX4tRdck/Sz53Nw2OUZI/AAAAAAAACT0/icLfGOBYQ8k/s720/DSC07543.JPG
http://lh3.ggpht.com/_mZNTX4tRdck/Sz53ON-MP8I/AAAAAAAACT4/tmZ_hiKb9FU/s720/DSC07549.JPG
http://lh3.ggpht.com/_mZNTX4tRdck/Sz53OUQPyDI/AAAAAAAACT8/5_TPX3BNo0s/s720/DSC07552.JPG
http://lh3.ggpht.com/_mZNTX4tRdck/Sz53Ou92r3I/AAAAAAAACUA/xdTSMc1kq08/s720/DSC07605.JPG
http://lh6.ggpht.com/_mZNTX4tRdck/Sz53O9OQQvI/AAAAAAAACUE/vRV83XXJOnI/s720/DSC07607.JPG
at the shop:
http://lh6.ggpht.com/_mZNTX4tRdck/Sz6CRCa3N-I/AAAAAAAACVk/53S41hdM4DA/s720/DSC09251.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz6CRf3BkCI/AAAAAAAACVo/LAoSlOy7Z7M/s720/DSC09250.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz6CRs-8e4I/AAAAAAAACVs/bYxGB-6JDU4/s720/DSC09333.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz6CRwuHQ9I/AAAAAAAACVw/tCtnp7X-88Y/s720/DSC09334.JPG
http://lh4.ggpht.com/_mZNTX4tRdck/Sz5wlUaA65I/AAAAAAAACQ0/fzQqAEtX6OY/s720/DSC09335.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5xOInuLhI/AAAAAAAACSU/yBehV6EAVvs/s720/DSC09766.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5wlyuj8OI/AAAAAAAACQ8/Fd0luVRSv_U/s576/DSC09734.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5wmOveyyI/AAAAAAAACRA/CWt6cOsA6bI/s720/DSC09732.jpg
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5wmWMlZEI/AAAAAAAACRE/jLzIJa_WW1I/s720/DSC09729.jpg
http://lh3.ggpht.com/_mZNTX4tRdck/Sz5xNAkwFpI/AAAAAAAACSE/J4uFzRNTwyk/s720/DSC09758.JPG
http://lh6.ggpht.com/_mZNTX4tRdck/Sz5xOaw2DxI/AAAAAAAACSY/eJgaHrYVch0/s720/DSC09767.JPG
Here you can see the slightly modded 199 alpine paint, we added more metallic and thus it has an amazing effect when in direct sunlight. Very bright silver with goldish gloss
http://lh4.ggpht.com/_mZNTX4tRdck/Sz5xNR2EheI/AAAAAAAACSI/8SKSekfqBcs/s720/DSC09759.JPG
And i let them surprise me with the hood, originally it was planned to keep it matt black, but they decided to make it look alot better as a small favour
http://lh3.ggpht.com/_mZNTX4tRdck/Sz5xNiyOsYI/AAAAAAAACSM/jSx1CFhE6KI/s720/DSC09760.JPG
http://lh5.ggpht.com/_mZNTX4tRdck/Sz5xN84L10I/AAAAAAAACSQ/0_MEcUtPM7E/s720/DSC09763.JPG
http://lh6.ggpht.com/_mZNTX4tRdck/Sz5xO2rMsQI/AAAAAAAACSg/dSjDuAOC25Q/s576/DSC09793.JPG
It makes a hell of a difference yes, just a few cans of paint.
In the next few months there will be alot of changes to the suspension setup.
new bushes, arms etc, all of this will be done before going to more engine upgrading.
Oh yeah, heres a graph of the mapping which was done in end 2008 with the Fcon fitted:
WHP
http://lh6.ggpht.com/_mZNTX4tRdck/Sz6KSLh3nOI/AAAAAAAACV4/jak8lFJ_f88/s512/Dyno%20run%20Re-Worx%202.jpg
Crank
http://lh6.ggpht.com/_mZNTX4tRdck/Sz6KSaeeCTI/AAAAAAAACV8/gswCPjjZzbE/s512/Dyno%20run%20Re-Worx%20small%201.jpg
Looks better now, what are you going to do about the damaged wheels?
Good question,
i was thinking about it for a few months and have decided to purchase 2 new ones, powdercoat all of them and either keep them, or sell them.
In any case I will be looking to purchase some other wheels with 10 fronts and 11 rears.
Good question,
Couple of new ones and everything powdercoated will look great, nice offset on them.
Yeah they will,
only thing i hate about em is that they are only avail. in 9,5j max.
these are +12 Offset allround
have too thin tyres on front and back.
fronts are 235 and rears 245.
will be 265 and 295 when 2 new wheels arrive.
Once that happens i will have to see how the car responds regaring grip.
PS sorry for the hijack, maybe mods could move this to a new thread if OP wants,
I knocked this up to try & understand the shape of the fender, I'm not sure that it's nay wider than a stock fender (although due to it's design there are parts that are wider) (ps it's a large image so give it time to load)
I'd say they look more like this in comparison to a stock wing, anyone agree/disagree?
