5.8 Psi - How many HP do you think ?
Guest J O H N S O N
Guest J O H N S O N
Hi Guys :)
Im running this setup :
*Jun Rods
*Jun Pistons.
*HKS head gasket.
*HKS 280 cams
*HKS wastegate
*Greddy T88-34D turbo
*Koyo Radiator
*Greddy Oil cooler
*Greddy intercooler 3 row.
*Veilside intake manifold m/100mm
*Screamer pipe
*custom pipes(polish)
*Greddy cathtank
*Greddy cam gears
*Greddy timing belt
*Sard fuel rail(polish)
*1000cc injectors Denso
*Greddy manifold
*HKS f-con engine manegement.
*HKS trible plate clutch
*Twin external fuel pumps
*Greddy pulley kit
*HKS twin power dli II
*Sard fuel regulator
The Cars is making 555 HP at 15,9 PSI - And about 800 at 24PSI ....
What do you think the Car would make at 5.8 Psi ?
We have some very strange MOT rules in my Country :/ Thats why im asking
Guest J O H N S O N
This guy had to pay 19.000 GBP - Cuz he put on a Compressor :(
http://www.bilgalleri.dk/uploads_xl_wm/875015.jpg
Guest J O H N S O N
Edge :
The police confiscated the car - And surrender to duty / tax authority :/ If they suspect that the car exceeds 20% of the normal HP
they will lay a charge before you can get the car back ...
  J O H N S O N said:
But is the Wastegate to big ( think its a HKS GT 60 mm ) to drive 5.8 Psi . .. ?
I think the wastegate minimum is determined by the spring? I don't think there is a minimum boost due to being a larger size, the bigger the better basically as it can control the boost of larger turbos easier.
You can take the wastegate out and change the spring to whatever you want AFAIK.
