front wheel studs
bradleyh_15
Easier, but WHY have they failed! Usual reason is wrong spigot hole diameter in the wheels and no, or poor hub adaptor rings. Poor equals plastic, badly fitting or too shallow a ring
Or over-torqued?
probably over-torqued as my mate still has my torque wrench!
chris by any chance do you have any front wheel studs?
also is there a guide on hear as I can only find one for the rear's!
It really is easy to do. Once you have the front disk off, it will be obvious how to get them out - you don't have to manouvre the stud around the handbrake mechanism on the front.
thanks mate ill have to have a go sunday!shame it will be out side as I don't have a big enough garage!
If by any chance you do have non-standard wheels fitted with an offset less than 50mm, then you may want to consider fitting longer than standard length studs to take that into account. I bet there's many driving around with only a few threads of the wheel nuts holding the wheels on!
thanks steve!
I have seven new ones and quite a lot of used ones from a car I fitted longer studs to. The new ones would be at retail Toyota price, I will have to check on Monday. I can send them with the pads on Monday, and you can pay me later that week if it helps? Although I don't think anything is wrong with the used ones I couldn't offer any guarantee and they'd be totally at your risk. If it were me I'd buy more new ones if you need to change the lot. Just let me know before Sunday evening please.
could I please take 5 new ones? just let me know monday the extra I need to transfer to you and ill send it straight away!
