Changing a Tial Diaphragm/Spring Cup Assembly
Kev.O
Has anyone ever changed one of these before? I have a V44 wastegate and it appears as though the diaphragm has been pierced when I test fitted the bolt in it :(:
I've looked around and you can get the diaphragms as a service part, but if they are that tricky to do/need specialist equipment then I'll look into sending it to a dealer over here.
Also on a side note, the dash 4 ended banjo's I'm now using are a little shorted in height than the ones that come suppplied. Am I ok to use two washers between the banjo and wastegate?
Edit: Quick how to guide in post #7.
Edited by Kev.O
How to guide note added. (see edit history)
I took a HKS one apart once (& I believe the diagphram can be purchased seperately for those) so there's no reason why you can't if you can get hold of a new diagpgram.
Becarefull taking it apart though, the tops come off with some force due to the spring inside, I undid the bolts & it was siezed on, so I tapped the top with a hammer, it shot across the garden :D
Edited by jevansio (see edit history)
http://i201.photobucket.com/albums/aa39/Casey-Kev/ResizeofTialWastegate004.jpg
Ref. the washers Kev. I'm thinking a Dowty washer would be more appropriate. They are quite a bit thicker.
No idea on the wastegate question I'm afraid.
What are you doing working on the car on New Years Eve anyway. Go down the pub. :D
I've already removed it, but thanks for the warning Jay.
If anyone ever does read this prior to removing the top, make sure you undo the bolts a little at a time, and opposite each other, a little like undoing a wheel :)
I'll look into a Dowty washer, thanks Andy. I'm on anti-biotics so can't drink until Saturday :(
:( bummer. Hope you're better soon.
Looking more closely at the connection and that washer seems quite thick anyway. As thick as a Dowty.
You can get different thickness coppers. I try never to use two washers. That's a personal thing though. :)
Wish you a happy new year and a hangover Sunday. :D
It's nothing big, just tonsilitus over the Christmas holidays :(. I'll certainly be feeling rough on Sunday :D
The washers are thin, just think the camera has reflected the two washers that are already fitted.
Happy new year to you too :)
Just for future reference, a 4mm allen key is required to undo the 6 bolts inorder to open the top of the wastegate.
Once inside, you'll need a 2mm allen key to undo the 4 grub screws:
With all 4 removed, you'll need to 'wiggle' the spring cup assembly off. The diaphragm membrane is simply laid in the gap and comes off easily:
In this picture you can clearly see where the grub screws are located once fitted:
Simply reverse this process to fit the new diaphragm :)
