steve6 Posted December 31, 2009 Share Posted December 31, 2009 ive heard the walbro is direct fit into jap hanger unlike uk oem pump,,,anyone know for sure Quote Link to comment Share on other sites More sharing options...
Homer Posted December 31, 2009 Share Posted December 31, 2009 The 342 walbro is a direct replacement in the jspec cars, the walbro 341 is a direct replacement in the Export spec cars but can be fitted to the jspec with some messing about The UK (export) spec pump cannot be retrofitted to a jspec hanger without modifcation to the hanger. Quote Link to comment Share on other sites More sharing options...
johnny g Posted December 31, 2009 Share Posted December 31, 2009 I got my Walbro from Paul @ Whifbitz. Comes with all needed bits to fit, took around 35-40 minutes. Quote Link to comment Share on other sites More sharing options...
Guest Suprafly Posted December 31, 2009 Share Posted December 31, 2009 That's where I got mine, just give paul a ring and he'll get the right one out to you next day. Quote Link to comment Share on other sites More sharing options...
GRIM Posted January 2, 2010 Share Posted January 2, 2010 The UK (export) spec pump cannot be retrofitted to a jspec hanger without modifcation to the hanger. but will it work with JDM pump ecu? or is there any other modification needed? Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 3, 2010 Share Posted January 3, 2010 No modification at all just plug and play. Either Walbro will fit if you do away with the rubber shoe at the bottom. Quote Link to comment Share on other sites More sharing options...
GRIM Posted January 3, 2010 Share Posted January 3, 2010 No modification at all just plug and play. Either Walbro will fit if you do away with the rubber shoe at the bottom. That's exactly the info I was looking for I was going to change my fuel pump but I have read that JDM and USDM/UK pump ecu is different and it won't work, so I was afraid and was ready to install walbro gss342, that's nice to hear, so now i can get a usdm/uk pump Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 4, 2010 Share Posted January 4, 2010 I ran a USA Walbro in my JDM car for years. I imported one, it was cheaper than buying a JDM type Walbro from a UK seller. It was quite a few years back though. Quote Link to comment Share on other sites More sharing options...
GRIM Posted January 4, 2010 Share Posted January 4, 2010 I'm talking about OEM USDM/UK Supra Denso Pump is it plug and play? except the hanger mod Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 4, 2010 Share Posted January 4, 2010 It has been a long time since I fitted the UK pump, I had to solder the wires on to the original plug, apart from that, it is just a matter of trimming the fuel connection hose from the pump to the outlet pipe. A couple of jubilee clips to hold the pump in place. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 4, 2010 Share Posted January 4, 2010 I'm talking about OEM USDM/UK Supra Denso Pump is it plug and play? except the hanger mod Yes. Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 4, 2010 Share Posted January 4, 2010 technicaly isnt the denso pump better than the walbro? is the reason everyone uses the walbro because its cheaper? Quote Link to comment Share on other sites More sharing options...
Jake Posted January 4, 2010 Share Posted January 4, 2010 Yes its better. The reasons folks use a Walbro also include the fact Walbro do a straight-swap replacement whereas fitting a UK spec Denso pump involves changing the hanger to fit a j-spec. Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 4, 2010 Share Posted January 4, 2010 The UK Denso pump is much more expensive than either Walbro Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 4, 2010 Share Posted January 4, 2010 what about the bosch 044 pump? isnt that a direct fit or does that need modification to the hanger also? Quote Link to comment Share on other sites More sharing options...
GRIM Posted January 4, 2010 Share Posted January 4, 2010 you can get an OEM Denso (UK/USDM) pump for about -170-200$ USD on eBay walbro's are about 90-100$ I don't think that 100$ difference is too much, is it? OEM is OEM anyway not so noisy and it's better quality overall IMO Quote Link to comment Share on other sites More sharing options...
dive_popo Posted May 23, 2011 Share Posted May 23, 2011 Hi, does anybody know what is the Toyota reference for the euro spec DENSO fuel pump ?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 23, 2011 Share Posted May 23, 2011 Here you go, UK / Euro spec fuel pump: Quote Link to comment Share on other sites More sharing options...
dive_popo Posted May 23, 2011 Share Posted May 23, 2011 Thanks Quote Link to comment Share on other sites More sharing options...
