Marco79 Posted December 30, 2009 Share Posted December 30, 2009 Went to change my glowplugs on my astravan and first one sheared (but stayed connected internally) and the rest are solid, I've soaked them in plusgas now hoping that might make a difference, any suggestions for the sheared one though? It's one thing after another with this van :-( Link to comment Share on other sites More sharing options...
JamesC Posted December 30, 2009 Share Posted December 30, 2009 Is this in the head unit or amplifier? Link to comment Share on other sites More sharing options...
Marco79 Posted December 30, 2009 Author Share Posted December 30, 2009 Is this in the head unit or amplifier? Lol it's the one in the head...... Unit Link to comment Share on other sites More sharing options...
movistar Posted December 31, 2009 Share Posted December 31, 2009 This might sound odd but try tighten them a little before you undo them ....it sometimes helps to crack em off first. Link to comment Share on other sites More sharing options...
tomgeer Posted December 31, 2009 Share Posted December 31, 2009 If you can get a drill in and make a pilot hole you could use extractors for the sheared one. A set off snap on ones are about £20, they come with the correct size drilll for each one. They are worth their weight in gold, I would recommend cheaper brands though because they just tend to snap under pressure. Link to comment Share on other sites More sharing options...
JustGav Posted December 31, 2009 Share Posted December 31, 2009 Have you checked whether you need to heat them before trying to remove them. They do sometimes require the head to be warm. Link to comment Share on other sites More sharing options...
trebor69 Posted December 31, 2009 Share Posted December 31, 2009 Definatly warm engine before trying to remove . Link to comment Share on other sites More sharing options...
Marco79 Posted January 1, 2010 Author Share Posted January 1, 2010 Cheers for the help guys yeah the engine was nice and warm when I was trying to change them, I've started soaking the remaining 3in plusgas to try and free them a bit, am tempted to leave them now tho and only tackle them if I get real starting problems, I have various easy outs I had wondered about using are these what your on about extractor wise tomgeer? Link to comment Share on other sites More sharing options...
tomgeer Posted January 1, 2010 Share Posted January 1, 2010 Cheers for the help guys yeah the engine was nice and warm when I was trying to change them, I've started soaking the remaining 3in plusgas to try and free them a bit, am tempted to leave them now tho and only tackle them if I get real starting problems, I have various easy outs I had wondered about using are these what your on about extractor wise tomgeer? Yes mate thats them, just try not to get any drill swarf into the head by drilling too deep. I also use a little gas soldering iron which is perfect for heating any troublesome components, If you unscrew the tip it works like a little blowtorch with a very accurate flame (so you don't burn anything you didn't want to), it worked a treat on my 02 sensor which was very tight. They are on ebay http://cgi.ebay.co.uk/Bernzomatic-PS-135-Butane-Gas-Soldering-Iron-Torch_W0QQitemZ160390166157QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item2557ffb68d Link to comment Share on other sites More sharing options...
bignum Posted January 1, 2010 Share Posted January 1, 2010 The glowplugs on my tranny connect aren`t even connected and it starts fine,i`d leave it if it starts ok. Link to comment Share on other sites More sharing options...
