New website issues (Firefox)
tomssupra
Get the Firebug extension for Firefox, then right click the area with the gap and select "Inspect Element" - this will show the code in the region you clicked. As you mouse over the HTML elements they will be highlighted in the rendered website.
When I view the link in Firefox 3.5.6 I see a big gap between your image and the navigation links below....is this the problem you are referring to?
If so, using Firebug, it would appear the gap is caused by the
element in the following section of code:
header_3_top_side_left.pnghttp://www.tomshosting.co.uk/Vanilla%2DBrown/preview/header_3_top_9.jpgheader_3_top_side_right.png
There a couple of things to try, the first and probably most suprising is to remove any line breaks/spaces between the opening
and the following tag, and do the same for the closing
. This usually causes issues in IE from my experience.
If that doesnt fix it, try giving the
a custom class - for example:
// CSS
p.trim
margin: 0;
padding:0;
// XHTML
If that doesnt do the trick, try the same with the
that the section of code is contained within.
There is a padding/margin issue somewhere though in my opinion.
PS: In IE8, the image doesnt align up correctly horizontally, its out by about 2px, its noticeable on the "Vanilla Brown" sign to the right.
