Squeaky sound from Pulley??
Guest mak0101
Guest mak0101
Hello guys, hope everyone had a food xmas! im new to supra owners club, bought my 2nd supra a month or so ago, but in the last few days i have isolated a squeaky noise coming from the front, top right hand side pulley. i always let me engine warm uup on start..this squeak starts after a few mins and does go away slightly when warmed up but not completely only goes after a bit of WD40 is applied...does anyone have any idea what needs to be done; i dont want to have to lube the pulley all the time. any suggestions guys?
Thanks
Mak
93 MK4 Toyota Supra, N/A, Auto!
Guest mak0101
Hi Phil, thanks for that! the cambelt was chaged about 8K Kms ago by last owner so i doubt it needs changing. if any of the pulleys are loose, is it an expensive job to replace? can the suspect pulley just be replaced or do they all have to be done? is there a quick fix? thanks
Guest mak0101
thanks mitchell. do you think if i change the auxilary belt would make a difference? do you know any place where it could be bought?
also, does anyone know of a mechanic in east london or surrounding essex area who is good with supra repairs? i dont want to spend an arm-an-a-leg though!
thanks guys!
Guest mak0101
thanks pudsey...the timing belt was changed about 8K kms ago and i dont know about the aux fan belt looks in pretty good condition too so i think it may not be a belt...right?
thanks for the info guys! i was listening to the car today aswell, along with the squealing sound, there's like a light 'clattering' sound coming from near the top front end of the block just above the TOYOTA 3000 sticker!...its probably does it for a few secs then goes away for about a minute! do you think it is the PAS pump and the top right front pulley (Power steering pump pulley i think) the culperates?
  • 3 weeks later...
Guest mak0101
hi guys...still got the annoying squeel coming from the p.s pump pulley and surrounding area. does anyone know where i can get reasonably priced pulleys or a ps pump from? thanks again guys
