phat supra Posted December 28, 2009 Share Posted December 28, 2009 wheres my water goin its takin about a full tank every 3 weeks any one help thanks Link to comment Share on other sites More sharing options...
nevins Posted December 28, 2009 Share Posted December 28, 2009 water leak or head gasket problem, has the car been running different to usual or been giving off a strange smell. Also check if your carpets wet inside the car. Link to comment Share on other sites More sharing options...
phat supra Posted December 28, 2009 Author Share Posted December 28, 2009 water leak or head gasket problem, has the car been running different to usual or been giving off a strange smell. Also check if your carpets wet inside the car. am really stuck on this one new head gasket last year when i had valve seals done car was only on the road for 3 weeks and been in the garage for about 16 weeks then only just gettin it back on the road about 4 weeks ago. running fine oil is clear no smell carpets are dry god only nows with this one any other idears thanks lee Link to comment Share on other sites More sharing options...
Scooter Posted December 28, 2009 Share Posted December 28, 2009 Old/knackered rad cap? Link to comment Share on other sites More sharing options...
nevins Posted December 28, 2009 Share Posted December 28, 2009 Check things while under pressure such as rad and connections, expansion tank, water hoses and connections. Best thing to do is get hold of a pressure test kit that simply attaches to the expansion tank, then simply build up the pressure and watch for the pressure to drop, this should also give away where the leak is as it will force the water out. Link to comment Share on other sites More sharing options...
phat supra Posted December 28, 2009 Author Share Posted December 28, 2009 Old/knackered rad cap? maybe think its the only thing i have nt tried thanks Link to comment Share on other sites More sharing options...
phat supra Posted December 28, 2009 Author Share Posted December 28, 2009 Check things while under pressure such as rad and connections, expansion tank, water hoses and connections. Best thing to do is get hold of a pressure test kit that simply attaches to the expansion tank, then simply build up the pressure and watch for the pressure to drop, this should also give away where the leak is as it will force the water out. ye will speake to my garage an see if they can do a test for me hope its the rad cap just looked at one of the tec threads thanks Link to comment Share on other sites More sharing options...
Terminator Posted December 29, 2009 Share Posted December 29, 2009 It may be better just to change the cap. Operating the system at higher than normal pressure may cause more problems that otherwise would not have occurred. Replace the cap with a standard pressure cap, not higher, as this can also trigger problems. Link to comment Share on other sites More sharing options...
nigelboyne Posted December 29, 2009 Share Posted December 29, 2009 silly question but you are using coolant and not plain water Link to comment Share on other sites More sharing options...
Stephen G Posted December 29, 2009 Share Posted December 29, 2009 Is yours a TT. Mine was losing a bit coolant and was traced down to a leaking water pipe on one of the turbos. Link to comment Share on other sites More sharing options...
Guigsy Posted December 29, 2009 Share Posted December 29, 2009 my old rad would loose water slowly. then the car started overheating on hot days when in trafic or not moving. The top of the rad up under the top of it (aftermarket ally one) was totaly fecked when the garrage looked at it. Put a stock one back in and its be great since. Link to comment Share on other sites More sharing options...
GreaseMonkey Posted December 29, 2009 Share Posted December 29, 2009 Just a thought, might be worth checking the Water Pump to see if it's leaking from behind the pulley or dried coolant buildup/ stains from/ around its overflow pipe?. Link to comment Share on other sites More sharing options...
Nic Posted December 29, 2009 Share Posted December 29, 2009 wheres my water goin its takin about a full tank every 3 weeks any one help thanks Standard expansion bottle or do you have an FMIC with smaller non-standard one fitted? Link to comment Share on other sites More sharing options...
