no water in expansion tank help
phat supra
water leak or head gasket problem, has the car been running different to usual or been giving off a strange smell. Also check if your carpets wet inside the car.
am really stuck on this one
new head gasket last year when i had valve seals done car was only on the road for 3 weeks and been in the garage for about 16 weeks then only just gettin it back on the road about 4 weeks ago.
running fine oil is clear
no smell carpets are dry
god only nows with this one any other idears
thanks lee
Check things while under pressure such as rad and connections, expansion tank, water hoses and connections. Best thing to do is get hold of a pressure test kit that simply attaches to the expansion tank, then simply build up the pressure and watch for the pressure to drop, this should also give away where the leak is as it will force the water out.
ye will speake to my garage an see if they can do a test for me hope its the rad cap just looked at one of the tec threads
thanks
my old rad would loose water slowly. then the car started overheating on hot days when in trafic or not moving. The top of the rad up under the top of it (aftermarket ally one) was totaly fecked when the garrage looked at it. Put a stock one back in and its be great since.
