pistonbroke Posted December 27, 2009 Share Posted December 27, 2009 I bought a set of genuin facelift indicators off Paul whiffen about 6 months ago. They were fitted when Supraloopy did my car makeover. Yesterday however when cleaning her, I noticed one of them had condensation in the lense where the sidelight is. Has anyone else had this issue?, is it normal,? or does it need replacing? Link to comment Share on other sites More sharing options...
Mcgoo Posted December 27, 2009 Share Posted December 27, 2009 Try a bit of Vaseline on the bulb holder seals, usually the problem with the headlights to. Link to comment Share on other sites More sharing options...
Ricky49 Posted December 27, 2009 Share Posted December 27, 2009 I had this aswell. As my car isn't facelift model there was no lamp in the side light bit of the indicator. Once LeeP wired up the side lights on the indicator to the side lights of the headlights and put a lamp in problem solved. With no lamp in moisture just got through. Link to comment Share on other sites More sharing options...
pistonbroke Posted December 27, 2009 Author Share Posted December 27, 2009 I have replaced the normal bulbs with LED's, so they emit little to no heat. Therefore, whatever moisture is in there is not being evaporated. I've taken the bulb holder out to let the air get to it and get rid of the moisture while the car is parked in my garage. Hopefully it will clear, and I'll do the vaseline thing. Cheers guys. Link to comment Share on other sites More sharing options...
martini Posted December 27, 2009 Share Posted December 27, 2009 I had this issue because I changed bulbs during quite a wet day. Now the outside air is less humid than inside, and the temperatures are colder; I've got condensation. I'll dry it out sometime before the spring and re-fit it. Link to comment Share on other sites More sharing options...
