jackso11 Posted December 27, 2009 Share Posted December 27, 2009 just about to fit a walbro fuel pump in my car and have read matts fitting instructions. Quick question, what should I use to insulate the soldered connections? Matt says insulate but tape will not do. Quote Link to comment Share on other sites More sharing options...
wilson4347 Posted December 27, 2009 Share Posted December 27, 2009 Heatshrink connectors? think these have been used for this. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 27, 2009 Author Share Posted December 27, 2009 I read that unless you use special fuel proof ones they don't last long either Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted December 27, 2009 Share Posted December 27, 2009 Fuel proof sleeving. Not heatshrink, but easy to apply with practice. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 27, 2009 Author Share Posted December 27, 2009 too late, done it with tape. Will have to order some of that stuff and change it soon. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 27, 2009 Author Share Posted December 27, 2009 just seen a post that says tape in the fuel tank is a BIG no no. Will this be ok for a couple of days before I get some of the fuel resistant heat shrink? I did stagger the connections so they won't connect if the tape vanishes Quote Link to comment Share on other sites More sharing options...
Guest Suprafly Posted December 27, 2009 Share Posted December 27, 2009 As long as the joints are staggered and clear from making contact with the cradle then theres no need to insulate them at all. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 27, 2009 Author Share Posted December 27, 2009 hmm, I don't think I would trust them not to move and touch the cradle as some point in the future. I don't suppose anyone has a tiny bit of the fuel proof heat shink I could have? I don't really want to buy 100s of little sleeves when I only need to do 2 wires. Quote Link to comment Share on other sites More sharing options...
Chewie Posted December 27, 2009 Share Posted December 27, 2009 Try using self fusing silicon tape. I use to stuff all the time. Better than heat shrink. get it from most DIY emporiums. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 27, 2009 Author Share Posted December 27, 2009 self fusing silicone tape? Is that basically fuel proof tape? Quote Link to comment Share on other sites More sharing options...
Chewie Posted December 27, 2009 Share Posted December 27, 2009 Self fusing silicon tape. Does exactly what it says on the box. I suppose it's like a very viscous gel. I'm looking at a roll of the stuff as I type. Never tried it on the terminals of a fuel pump but there's always the first time... hang about just checked chemical resistance charts and silicon rubber isn't too clever with petrol. Scrub that idea. Quote Link to comment Share on other sites More sharing options...
dude Posted December 27, 2009 Share Posted December 27, 2009 You can get brush on insulating tape, I will need to have a look and see if its fuel proof Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 28, 2009 Author Share Posted December 28, 2009 i will be going out this afternoon to find something so ideas please do you know if the brush on stuff is good dude? Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 28, 2009 Share Posted December 28, 2009 If you can't get fuel proof tape, just use some small bore fuel hose as a sleeve held in place with tie wraps. Worked fine on my car, 5 years on it was fine. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 28, 2009 Author Share Posted December 28, 2009 fuel hose sleeve, good idea. I was thinking of some kind of sleeve but not sure what is fuel proof. I will go to halfords and see what they have to offer Quote Link to comment Share on other sites More sharing options...
Wez Posted December 28, 2009 Share Posted December 28, 2009 fuel hose sleeve, good idea. I was thinking of some kind of sleeve but not sure what is fuel proof. I will go to halfords and see what they have to offer He means use some small bore fuel hose AS a sleeve, Halfrauds or AllParts should have some in stock Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 28, 2009 Share Posted December 28, 2009 I sell Raychem fuel proof heat shrink. £5 a foot. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted December 28, 2009 Author Share Posted December 28, 2009 job done. I used fuel hose in the end. A word of warning to anyone searching for this in future, insulation tape is not a good idea. I put it on yesterday thinking it would be fine until I order some heat shrink, today when I got the pump out again the tape was just like plastic with a gooey mess on where the glue should be. 24hrs and it has turned to useless plastic, do not use even as a quick fix. Picture attached of what I ended up with. Quote Link to comment Share on other sites More sharing options...
