Supradk Posted December 26, 2009 Share Posted December 26, 2009 hi guys i have get my car from jurgen where they install a cobra alarm model 4100;) when it was on its way home the central door locking stopped to work. have you any idea what could cause it?? here is a link to the install guide. Can you say if it is A,B or C install used on supra? bottom end of site:p http://www.bylow.dk/Nonsec/webselv/bylowweb/docs/1/4100_montering_DK.pdf do you know what colour the harness are on sup where i put on cobra harness?? thanks kåre, its a 6 speed tt:d Link to comment Share on other sites More sharing options...
Supradk Posted December 26, 2009 Author Share Posted December 26, 2009 anyone....? :-) when i sit in the car and swith the lock button on and of it dont work? Can it be a help to you?? Link to comment Share on other sites More sharing options...
Guest Budz86 Posted December 26, 2009 Share Posted December 26, 2009 Probably a good idea to drop Jurgen a PM and ask him directly mate Link to comment Share on other sites More sharing options...
Supradk Posted December 26, 2009 Author Share Posted December 26, 2009 done that. But people here know a lot of things and maybe its just a fuse? little problem like this takes a lot of time :-P Link to comment Share on other sites More sharing options...
Supradk Posted December 26, 2009 Author Share Posted December 26, 2009 its the A connection which is done on my supra. The purple/orange is connect to ground. orange harness to a yellow/black and the purple is connected to a grey one. all connected in driver site in fuse box :-) Link to comment Share on other sites More sharing options...
trebor69 Posted December 26, 2009 Share Posted December 26, 2009 Mine did that the other day ........ stand next to car and press both buttons on fob until led stops flashing (approx 10 seconds) then press central locking button for approx 1 second , this should reset it . Link to comment Share on other sites More sharing options...
Supradk Posted December 26, 2009 Author Share Posted December 26, 2009 my remote have 3 buttons. lock and unlock and a bottun look like a key or something. so which of them do i have to press both and which is the central locking bottun? Link to comment Share on other sites More sharing options...
trebor69 Posted December 26, 2009 Share Posted December 26, 2009 thats different than mine , (mine has two buttons) , one for lock and unlock and the other for alarm , i'd try a combination of all three first and then the unlock one , etc , etc . Its common for mine to do this and it is a cobra too . Link to comment Share on other sites More sharing options...
trebor69 Posted December 26, 2009 Share Posted December 26, 2009 When mine does this i can use my other fob and it be ok , do you have a second fob ? have you tried it ? Link to comment Share on other sites More sharing options...
Supradk Posted December 27, 2009 Author Share Posted December 27, 2009 tried it. still not working :-/ Also tried the second fob i have. :-( Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 27, 2009 Share Posted December 27, 2009 anyone....? :-) when i sit in the car and swith the lock button on and of it dont work? Can it be a help to you?? Yep, that helps a lot. It's very unlikely to be the Cobra at fault here, unless the installers have managed to join both lock and unlock wires together, in which case it would never have worked. The installation of an alarm, unless installed appalingly, will never stop the cars central locking from working. All the alarm does is puts a pulse down the factory system to activate the central locking relay as if you had pressed the button on the drivers door. It cannot stop that switch from working, (Again, unless installed by a blind version of Edward Scissorhands). First place I would suggest looking is in the drivers door. Unplug the window/locking switch and check there is no water or condensation inside. There have also been a couple of recent threads about the drivers door lock switch causing a problem. Having never experienced this personally, I can't make an informed suggestion, but worth a look. It could also be the central locking control relay located behind/beside the glovebox. Link to comment Share on other sites More sharing options...
trebor69 Posted December 27, 2009 Share Posted December 27, 2009 tried it. still not working :-/ Also tried the second fob i have. :-( Sorry pal but i'm out of ideas ! Good luck with it Link to comment Share on other sites More sharing options...
Supradk Posted December 28, 2009 Author Share Posted December 28, 2009 (edited) http://www.bilgalleri.dk/alb_vis.aspx?AlbumID=56792 here is pic of it. how can i check that it works fine?? Edited December 28, 2009 by Supradk (see edit history) Link to comment Share on other sites More sharing options...
