Aerotop Dave Posted May 11, 2005 Share Posted May 11, 2005 New alphabetical version (posted 02 Sept) if a Mod wants to delete all the guff and just leave this post. Newer version posted 07 Sept with common interweb terms removed - it's now purely a Supra abbreviation guide All replies (and this text) can be removed AFR - Air Fuel Ratio BHP - Brake horse power BOV - Blow-off valve BPU - Basic performance upgrade DAT/File - RLTC settings file EBC - Electronic Boost Controller EBV - Exhaust Bypass Valve ECU - Electronic Control Unit EGCV - Exhaust Gas Control Valve EGR - Exhaust Gas Recirculation EGT - Exhaust Gas Temp EMS - Engine Management System EPC - Electronic Parts Catalogue EWG - External Waste gate ETTC - Electronic True Twin Conversion FCD - fuel cut defender FMIC - Front mount intercooler FPR - Fuel Pressure Regulator HIDS - High intensity discharge lighting IACV - Idle Air Control Valve IC - Intercooler Import - The Japanese import version of the Supra Jap spec - The Japanese import version of the Supra JDM - Japanese domestic market J-Spec - The Japanese import version of the Supra Lepton - undefined (for legal purposes) numeric value for measuring speed, as in 'I was doing 45 leptons in a 30mph limit' LSD - Limited Slip Differential MAF meter - Mass Air Flow meter MAP sensor - Manifold Absolute Pressure sensor MAT sensor - Manifold Air Temperature sensor MOD - Modification of car from standard N/A - Normally Aspirated NA - Normally Aspirated NA-T - single-turbo'd NA engine. RLTC - Racelogic Traction Control RWHP - Rear wheel horse power Single - Removing both stock turbos and fitting one big turbo instead (not really an abbreviation but useful to know) SLD - Speed limit defender SLD - Speed limit defenser SMIC - Side-mount intercooler STTS - Sequential Twin-Turbo Setup Targa - Incorrect and just plain wrong misnaming of the Aerotop version TC - Traction control TPS - Throttle Postition Sensor TRAC/File - RLTC settings file TT - Twin Turbo TT6 - Twin Turbo, 6 Speed manual TTC - True Twin Conversion TVD - Torsional Vibration Damper (a.k.a. front crank pulley) UK - The UK version of the Supra VVTi - Variable Valve Timing intelligent WI - Water Injection Link to comment Share on other sites More sharing options...
Digsy Posted May 11, 2005 Share Posted May 11, 2005 BHP - Brake horse power BOV - Blow-off valve BPU - Basic performance upgrade EBV - Exhaust Bypass Valve ECU - Electronic Control Unit EGCV - Exhaust Gas Control Valve EGR - Exhaust Gas Recirculation EGT - Exhaust Gas Temp EPC - Electronic Parts Catalogue FCD - fuel cut defender FMIC - Front mount intercooler IACV - Idle Air Control Valve IC - Intercooler Import - The Japanese import version of the Supra Jap spec - The Japanese import version of the Supra JDM - Japanese domestic market J-Spec - The Japanese import ver... you get the idea LSD - Limited Slip Differential MAF meter - Mass Air Flow meter MAP sensor - Manifold Absolute Pressure sensor MAT sensor - Manifold Air Temperature sensor N/A - Normally Aspirated NA - Normally Aspirated RWHP - Rear wheel horse power Single - Removing both stock turbos and fitting one big turbo instead (not really an abbreviation but useful to know) SLD - Speed limit defenser SMIC - Side-mount intercooler (the stock unit in other words) STTS - Sequential Twin-Turbo Setup TC - Traction control TPS - Throttle Postition Sensor TT - Twin Turbo TTC - True Twin Conversion TVD - Torsional Vibration Damper (a.k.a. front crank pulley) UK - The UK version of the Supra VVT-i - Variable Valve Timing - intelligent Link to comment Share on other sites More sharing options...
tbourner Posted May 11, 2005 Share Posted May 11, 2005 Added a few and put them in alphabetical order Smart arse. Link to comment Share on other sites More sharing options...
Supragal Posted May 11, 2005 Share Posted May 11, 2005 Edited a spelling mistake but nice work Dave! Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 11, 2005 Share Posted May 11, 2005 I've one SLD - Speed limit defender removed none technical Link to comment Share on other sites More sharing options...
Supragal Posted May 11, 2005 Share Posted May 11, 2005 SLDs in there you Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 11, 2005 Share Posted May 11, 2005 bollox Link to comment Share on other sites More sharing options...
Ian R Posted May 11, 2005 Share Posted May 11, 2005 RLTC- Racelogic Traction Control Link to comment Share on other sites More sharing options...
TazUK Posted May 11, 2005 Share Posted May 11, 2005 Can we add a description for lepton? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 11, 2005 Share Posted May 11, 2005 cant u all forgot WOT = Wide open throttle its a classic!! Link to comment Share on other sites More sharing options...
Class One Posted May 11, 2005 Share Posted May 11, 2005 GLF= Go like fuck!!! Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 2, 2005 Share Posted July 2, 2005 Another couple... ETTC - Electronic True Twin Conversion TT6 - Twin Turbo, 6 Speed manual Link to comment Share on other sites More sharing options...
Ian R Posted July 2, 2005 Share Posted July 2, 2005 and another:- Hids - High intensity discharge lighting Link to comment Share on other sites More sharing options...
far Posted August 30, 2005 Share Posted August 30, 2005 iirc if I remember correctly Link to comment Share on other sites More sharing options...
ScuttleRX Posted August 30, 2005 Share Posted August 30, 2005 FFS... for **** sake Link to comment Share on other sites More sharing options...
RobSheffield Posted August 30, 2005 Share Posted August 30, 2005 HTH - hope this helps FWIW - For What its Worth Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted August 31, 2005 Share Posted August 31, 2005 MOD - Modification of car from standard MOD - Moderator of forum Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted September 2, 2005 Share Posted September 2, 2005 removed Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 2, 2005 Share Posted September 2, 2005 EBC = Electronic Boost Controller AFR = Air Fuel Ratio Link to comment Share on other sites More sharing options...
Jake Posted September 2, 2005 Share Posted September 2, 2005 This thread should be for Supra related abbreviations only. If you don't know what a common internet abbreviations means then please go to http://www.acronymfinder.com Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted September 2, 2005 Share Posted September 2, 2005 ok, sorry Link to comment Share on other sites More sharing options...
Aerotop Dave Posted September 2, 2005 Author Share Posted September 2, 2005 Oh. Too late now, I've put them in. Shall I take them out? (I've re-done the first post in this thread) Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 2, 2005 Share Posted September 2, 2005 FPR= Fuel Pressure Regulator WI = Water Injection Link to comment Share on other sites More sharing options...
Jake Posted September 2, 2005 Share Posted September 2, 2005 Oh. Too late now, I've put them in. Shall I take them out? Up to you really Dave, you're the Mod. Thing is, there's eleventy zillion internet abbreviations and plenty of other sites that already cater for translating them. We could list them all but it seems a bit redundant to me. Your call though mate, I don't mind either way. This the Supra - Technical - FAQ though . . . Link to comment Share on other sites More sharing options...
Ian C Posted September 2, 2005 Share Posted September 2, 2005 Up to you really Dave, you're the Mod. Thing is, there's eleventy zillion internet abbreviations and plenty of other sites that already cater for translating them. We could list them all but it seems a bit redundant to me. Your call though mate, I don't mind either way. This the Supra - Technical - FAQ though . . . NA-T - single-turbo'd NA engine. -Ian Link to comment Share on other sites More sharing options...
