want more hp for my TT AT
Guest mydream
Guest mydream
hi@all im a newbie about cars i bought a supra TT Automatic
j-spec and want more hp
in the car are now some parts
-Apexi Power Intake
-hks exhaust
-BLITZ SERIES AC BOOST
and hks blow off
what do i need to get 400-500 hp
how much will ist cost
please write the full name from the part which i need
i dont know really what it menas
Guest Suprafly
It's all about how much power you want.
Doing full BPU will see you around 400bhp, I did this in October, all stuff you can do yourself on your drive or in your garage if you have one, the latter is probably best at this time of year though.
Although having said that, you might need to get it on a lifter to fit the 1st and 2nd cats as this can be a nightmare.
You already have a decent exhaust fitted which is about the most costly item, and you can loose your boost controller as you'll not need it, the rest should cost you under 500GBP
If you're going for 500+BHP then you'll be looking at doing a single turbo conversion which is considerably more.
Edited by Suprafly (see edit history)
