Dave Posted December 21, 2009 Share Posted December 21, 2009 its a 1.7 td was starting to get a bit of a pig to start as the weater got colder the other morning wouldnt go at all so change the g/plugs checked there getting power got 1/2 tank diesel charged up the battery .checked pipes for leaks even tried easy start its not starting used my mates diesel car to try and jump it no good --im out of ideas---- anyone ??? it doesnt seem to turn over as quick as it used to even on a jump lead or with the battery fully charged . Quote Link to comment Share on other sites More sharing options...
Glosphil Posted December 21, 2009 Share Posted December 21, 2009 Fuel return pipe split Quote Link to comment Share on other sites More sharing options...
tomgeer Posted December 21, 2009 Share Posted December 21, 2009 Fuel filter? I'm only saying that because a diesel compressor we have at work turns over slowly and won't start when the filter needs changed Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 21, 2009 Share Posted December 21, 2009 any eml's ?? Quote Link to comment Share on other sites More sharing options...
absz Posted December 22, 2009 Share Posted December 22, 2009 if its not turning over quick enough in the cold weather due to a lazy starter motor then it will not start, try tow starting it. Quote Link to comment Share on other sites More sharing options...
Dave Posted December 22, 2009 Author Share Posted December 22, 2009 any eml's ?? p0400 egr valve ---- p1635 glow pug circuit looking on the vx forums it could be the egr blocked full of crap so going to give it a clean and see how we go from there i think we got the glow plug code cause we change the plugs thanks for your input guys Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 22, 2009 Share Posted December 22, 2009 p0400 egr valve ---- p1635 glow pug circuit looking on the vx forums it could be the egr blocked full of crap so going to give it a clean and see how we go from there i think we got the glow plug code cause we change the plugs thanks for your input guys I got that code but my egr was fooked. mine would start but then go straight to limp home mode. Took it off cleaned it up and its been fine since. Quote Link to comment Share on other sites More sharing options...
movistar Posted December 28, 2009 Share Posted December 28, 2009 valve clearances could be too tight(they close up over time)the valves rise up slightly into the head, closing the valve clearance gap...this was quite a common fault years ago. Should be part of every major service but most people dont check them!! Just a case of re-shimming the tappets, quite an easy job if your in the know. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 28, 2009 Share Posted December 28, 2009 I had the 2.2 TDi engine. Exactly the same thing happened with me. Was getting a bit of a pig to start but after that it was fine. Turned out to be the valve seals AFAIK. Quote Link to comment Share on other sites More sharing options...
