Anyone ever called Homeserve?
Dash Rendar
My boiler appears to have stopped working this afternoon. :(
I've got gas boiler insurance through Homeserve. I called their 24hr emergency line 90 mins ago... and I'm still waiting to get through!
i set up all their phone lines, if you have any problems getting through drop me a PM and i'll see if i've got any direct numbers that bypass the IVR system..
Or try 01772 758 and then any 3 digits after that as have 2000 numbers from 01772 75 but 758 is the main range
I'm guessing you've recently started putting the central heating on a lot more??
That tends to send a lot of cack through the system from the rads and blocks the secondary heat exchanger. It's a quick fix, couple of hours soaking in cleaner / acid wash.
The boiler stops working because you have either a large pressure drop across the heat exchanger or it may be because the boiler is protected by a temp stat. If the stat sees something like a 35 degree difference it'll shut down.
Guess who's had to fix their boiler recently. :D
