Intake?!?
Guest KSTUNING
Certainly a 3.4 with could use an uprated plenum. The stock plenum would certainly hold it back. Probably not much point, if goals are below 600 bhp. However for higher power with bigger duration cams 280s+ and higher lift, you need a well balanced and high flow plenum to make the potential translate into actual power.
Edited by Terminator (see edit history)
