Wez Posted December 18, 2009 Share Posted December 18, 2009 Hey All, Are there any kits available or a part list of what's needed to remove the stock oil cooler, when I strip the inlet side down I will be junking the cooler as I already have a front mount oil cooler. Does the NA possibly use an adapter with the oil cooler part on it? Thanks Quote Link to comment Share on other sites More sharing options...
Lee P Posted December 18, 2009 Share Posted December 18, 2009 Hey All, Are there any kits available or a part list of what's needed to remove the stock oil cooler, when I strip the inlet side down I will be junking the cooler as I already have a front mount oil cooler. Does the NA possibly use an adapter with the oil cooler part on it? Thanks The only thing I would say though is the stock one is a heater as well as a cooler. It helps the oil get up to temperature quicker. If you want to do it though there is an adapter you can by from ford which allows the filter to bolt straight on to the block. The info is on the supraforums some where. Quote Link to comment Share on other sites More sharing options...
hodge Posted December 18, 2009 Share Posted December 18, 2009 Ill be doing this with my new engine. i was going to use the N/A's oil filter pick up as it doesnt have a stock oil cooler and an external oil cooler sandwich plate with a thermostat in. I think paul whifin sells them. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 18, 2009 Author Share Posted December 18, 2009 The only thing I would say though is the stock one is a heater as well as a cooler. It helps the oil get up to temperature quicker. If you want to do it though there is an adapter you can by from ford which allows the filter to bolt straight on to the block. The info is on the supraforums some where. Actually I think I recall reading about this is Ryans track car thread Ill be doing this with my new engine. i was going to use the N/A's oil filter pick up as it doesnt have a stock oil cooler and an external oil cooler sandwich plate with a thermostat in. I think paul whifin sells them. That sounds ideal as I would need maintain my current oil cooler setup Quote Link to comment Share on other sites More sharing options...
hodge Posted December 18, 2009 Share Posted December 18, 2009 I think the idea of the thermostat keeps the sandwich plate from opening until its up to temp so the oil heat to a good temp before it needs cooling. Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 20, 2009 Share Posted December 20, 2009 I think the idea of the thermostat keeps the sandwich plate from opening until its up to temp so the oil heat to a good temp before it needs cooling. Spot on! My HKS kit starts to feed oil to the cooler at 70 +/- 3 degrees and is fully open at 80 +/-3 degrees. Quote Link to comment Share on other sites More sharing options...
bondango Posted December 20, 2009 Share Posted December 20, 2009 (edited) Phil we just use the NA filter brackets and run the old oil heater/cooler water line straight to the block, just remember to renew the gasket on the housing pn 90301-68005 Edited December 20, 2009 by bondango (see edit history) Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted December 20, 2009 Share Posted December 20, 2009 weres my hammer? Quote Link to comment Share on other sites More sharing options...
hodge Posted December 20, 2009 Share Posted December 20, 2009 Phil we just use the NA filter brackets and run the old oil heater/cooler water line straight to the block, just remember to renew the gasket on the housing pn 90301-68005 Is that part number for the ;arge rubber o-ring between the block and filter bracket mate. Quote Link to comment Share on other sites More sharing options...
bondango Posted December 20, 2009 Share Posted December 20, 2009 Is that part number for the large rubber o-ring between the block and filter bracket mate. yep Quote Link to comment Share on other sites More sharing options...
Wez Posted December 20, 2009 Author Share Posted December 20, 2009 Phil we just use the NA filter brackets and run the old oil heater/cooler water line straight to the block, just remember to renew the gasket on the housing pn 90301-68005 Top stuff, will speak to Mr Toyota tomorrow Do you have the PN for the NA filter bracket? Quote Link to comment Share on other sites More sharing options...
bondango Posted December 20, 2009 Share Posted December 20, 2009 GE bracket is 15670-46070 though with the number of GE engines floating about i would just put a wanted up Quote Link to comment Share on other sites More sharing options...
Wez Posted December 20, 2009 Author Share Posted December 20, 2009 GE bracket is 15670-46070 though with the number of GE engines floating about i would just put a wanted up Good idea Quote Link to comment Share on other sites More sharing options...
