1jz from a soarer into a supra.
mitsi_matt
right i have a manual soarer tt, after smashing it a little at norfolk arena drift days & purchasing a mk4 supra tt for a dailydriver (which i love) have decided i would like another one for a pro drift car build, planning on buying a n/a auto for mucho cheapness & plonking the soarer 1j engine box etc in.
question 1: will everything bolt straight up?
2: would i need to use the n/a supra prop, soarer prop, get a supra tt prop?
3: do supra n/a come with torshen diff if not does the soarer one fit?
4: would i need anything else for the swap?
want to get a budget together dont want to be left with another project car i cant use due to overlooking a essential item i cant afford.
i do love my soarer just think that a full comp spec supra would perform better & certanly stand out more there were a few soarers competing in the uk this year not totally sure but have not spotted 1 serious spec supra, shorter wheelbase is more suited to my taste. & the supra seems to generate more traction.
about bloody time tbh! still cant understand why there is not more already. will have to checkout the project section for some insparation.
Mainly due to cost, the Supra is an expensive toy when it comes to motorsport. Also, she's a big heavy girl and can be a little bit violent when shifting the weight about.
the weight thing can be an advantage with drifting, i found my old s13 extreamly snappy when i put it on a weight reduction plan. the soarer i have has full interior ac the lot & its better than any leightweight car i have drifted even on a small track such as pod or norfolk arena! the cost thing i do understand after buying my road car but most serious drift drivers are more than compitant spinning spanners so: soarer auto for the engine ecu etc + supra na + 7m turbo r154 + jz bellhousing is far from expensive in comp car terms.
