vvti throttle problems
jawan
Hi,
I am having problems with throttle, basically if i reset the ecu, the car idles fine and drives fine but when i switch off and start the car again, i get engine light and no throttle. Not sure which sensor on throttle body is causing this or is it some thing else. so far i have removed the delimter but car use to drive fine with this delimiter fitted, so it must be something else causing this. Is there any way i can test which sensor causing this.
thanks
