Help ! Bit of a PC Problem
Muffleman
And it's serious, the missus can't get on Facebook :faint: :D
On bootup it's saying there is a missing system32\file, so I popped in the windows disk and hit 'r' to repair it. Problem is it's saying there aren't any hard drives, and the bios recognises them fine and they are whirring away quite happily.
Have I got to reformat the hdd ? :(
That's a strange one. The computer knows that there are hard disks present and working and that Windows is installed on the bootable partition, otherwise it wouldn't give you a "missing system32\file" message.
Could you post up the exact error messages, then we can narrow it down more. If I had to guess at this stage I'd say maybe a corrputed registry (see link) but I might be way off.
http://www.daniweb.com/forums/thread18179.html#
Need the exact message matt as Steve said. Could be your partition map is screwed up and it's getting so far then could be failin on the hardware abstraction process which has a number in it to look for a certain partition on various drives. If this gets corrupt you need to boot off cd onto a dos prompt and manually edit if possible.
It may be that the computer has a serial ATA hard drive (SATA) rather than IDE.
When you install or re-install it may ask you if you have any drivers you want to load and it may be looking for drivers for the sata / raid controller which the hard disk is connected to, if the drivers for it are not loaded it will not be able to detect the disk and could be why it is showing you that error. Which would fit in with the boot / bios screen showing the disks detected but them not showing up under the install.
When XP came out it was around or before the whole SATA disk thing kicked off so not may have the drivers for it.
What you 'could' do is get yourself on you favourate illegal torrent site and download an official windows XP service pack 3 CD which someone has put together and use your official CD key when it asks, you will likely find the updated disk has sata drivers.
Could be something completely unrelated to that of course but just a hunch :)
Interesting info about SATA: I wouldn't have thought Winodws would need the SATA drivers if the motherboard's chipset has the drivers built-in (which it will have otherwise it wouldn't be able to look on the hard disk in the first place), but I'm willing to be proven wrong. Every day's a school day, and I've got a lot of learning to do. :)
As an aside, Microsoft make all their OS Service Packs freely downloadable from their own website. No need to go to a torrent for them.
I'm putting my money on this :
Error Message: Cannot Find \Windows\System32\hal.dll
Where normally it's looking for partition 1 or 2 possibly for the file to know what hardware it's running.
If it is, see here http://www.kellys-korner-xp.com/xp_haldll_missing.htm
Can be blatted over when it doesn't need to be when repairing with an XP CD and you have a partitioned HDD or more than one HDD and the XP partition is not on the 1st partion on the 1st drive.
If you don't have a partitioned HDD or only have one HDD though Matt just ignore this and give us the full error message.
Can't be too much use myself though, haven't used XP at home much for 5+ years now. Buy a Mac, a lot easier to fix and restore :)
Usually build my own, but bought a Dell for the downstairs office so the missus could use a pc other than mine :eyebrows: It's a dimension 9150. No partitions either :)
I'll get the full message and post up.
Cheers all :)
AH, I see Dude has left his username logged onto my pc, how can I use this to wind him up :eyebrows:
dude? You guys share a wife or something???
Or is dude just your name in office hours?
I knew you guys were good friends but not that good!
That's not what he meant. He was talking about an XP install disk that has got SP3 slipstreamed into it.
Right, the error is :
Windows could not start because the following file is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM.
If I boot in safe mode, it comes up with the above error straight after this file :
multi(0)disk(0)rdisk(0)partition(2)windows\system32\config\system.log
The bios sees both sata drives, but if I try and reinstall windows to either drive, windows says there aren't any drives attached :search:
On the upside, the house is much tidier and I've been eating well, I almost don't want to let her have facebook back :D
Hey Matt,
I've had this before on a couple of PC's. This solution HERE has helped me in the past (provided you have a 2nd PC or a Laptop etc handy).
Have you tried hitting 'F8' when it's booting to see if the boot menu appears? I think this error would probably be happening before you get to this point, but worth trying just incase. If you can get there, try the 'Load Last Known Good Configuration' option.
You could also try running the Check Disc with Recovery option from the Windows CD to see if that does anything. So boot from the Windows CD and press 'R' for recovery. Go to the 'Command Line' mode (I forget exactly what it's called) and type "chkdsk C:/R (assuming that C: is your hard drive with Windows on it). This 'should' run the checkdisc feature with the recovery built in for when/if it finds any issues.
Geeks of the world unite!
Cheers, J
