JakeG Posted December 15, 2009 Share Posted December 15, 2009 my in car electrics aint wrking, a/c, heated seats, blower etc arent working, but the radio wrks and the lights on the dash seem very dim? any help?? Link to comment Share on other sites More sharing options...
devan Posted December 15, 2009 Share Posted December 15, 2009 Have you checked the fuses? Link to comment Share on other sites More sharing options...
JakeG Posted December 15, 2009 Author Share Posted December 15, 2009 Have you checked the fuses? Not yet no, i no thats the obvious reason it could be but im just checking to c if any1 knows straight away Link to comment Share on other sites More sharing options...
supra steveo Posted December 15, 2009 Share Posted December 15, 2009 fuses mate fuse box under the bonnet check all fuses , and check all fuses in the dvr`s kick well Link to comment Share on other sites More sharing options...
JakeG Posted December 15, 2009 Author Share Posted December 15, 2009 its a 1996 SZ by the way Link to comment Share on other sites More sharing options...
supra steveo Posted December 15, 2009 Share Posted December 15, 2009 yep it will still have fuse boxes Link to comment Share on other sites More sharing options...
trinitom Posted December 16, 2009 Share Posted December 16, 2009 that's the fuse, cig lighter fuse 15amp Link to comment Share on other sites More sharing options...
JakeG Posted December 16, 2009 Author Share Posted December 16, 2009 yep it will still have fuse boxes I no the car has fuse boxes, thanks for reminding me lol , was just leting you no what model i got, will check the fuses tomorow to see whats happening Link to comment Share on other sites More sharing options...
JakeG Posted December 16, 2009 Author Share Posted December 16, 2009 that's the fuse, cig lighter fuse 15amp thanks m8, will get a look in the mourning cheers Link to comment Share on other sites More sharing options...
Nic Posted December 16, 2009 Share Posted December 16, 2009 See here, page 18 shows fuse diagram http://www.turbosupras.com/pdfs/JZA80%20TSRM/Electrical%20Diagrams.pdf Link to comment Share on other sites More sharing options...
j1mb0b1 Posted December 16, 2009 Share Posted December 16, 2009 Yup as said above sounds like fuse bud check them all out. Link to comment Share on other sites More sharing options...
Ian C Posted December 16, 2009 Share Posted December 16, 2009 Please don't use text speak. Thank you -Ian Link to comment Share on other sites More sharing options...
supra steveo Posted December 16, 2009 Share Posted December 16, 2009 I no the car has fuse boxes, thanks for reminding me lol Link to comment Share on other sites More sharing options...
JakeG Posted December 20, 2009 Author Share Posted December 20, 2009 I have now checked the fuses under the bonnet, thay are all fine, now i need help?? Link to comment Share on other sites More sharing options...
kjgreen3 Posted December 20, 2009 Share Posted December 20, 2009 I've had the same problem it will be the 10 or 15 amp (cant remember) fuse in the drivers footwall, next to the accelerator. Check all fuses in there, use long nose pliers or tweezers to pull them out if you dont have the correct tool to remove them. Link to comment Share on other sites More sharing options...
Abz Posted December 20, 2009 Share Posted December 20, 2009 I have now checked the fuses under the bonnet, thay are all fine, now i need help?? Have you checked under the driver's side footwell? You will have a number of fuses here, they are not as easy to access and you might need a torch along with a small appliers or flat head screw driver if your delicate (as they fling out). Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 20, 2009 Share Posted December 20, 2009 I assume this isn't just a flat battery? - Dim dash lights? Link to comment Share on other sites More sharing options...
JakeG Posted December 20, 2009 Author Share Posted December 20, 2009 I forgot about the drivers footwell fuses, hada check in the mourniong thanks Link to comment Share on other sites More sharing options...
