Guest BlackVelvetGuns Posted December 15, 2009 Share Posted December 15, 2009 Hi, ive had my 1996 Supra TT for 3 years now and a year ago i upgraded to 19 inch wheels, 18's were on previously. Since they've gone on if im driving somewhere i haven't been before im constantly checking the road for potholes, dips etc. Even at slow speeds hitting a bump causes my drivers side front tyre to hit the underside of the arch. The suspension on the front is aftermarket gear which is a lowering kit, this has been fully extended but still isnt enough. Im considering buying standard struts and springs for the front to lift the car and hopefully eliminate the problem and enable me to drive over bumps in the road without stressing! A breakers yard has quoted 200 quid for the standard front struts and springs. Anyone with thoughts or previous experiences of the same kinda probs? The rear suspension is fine. Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 15, 2009 Share Posted December 15, 2009 What tyre sizes do you have on? It may be that they are wrong and too tall. However, ultimately you'd do better to go back to 18" wheels. Quote Link to comment Share on other sites More sharing options...
Guest BlackVelvetGuns Posted December 15, 2009 Share Posted December 15, 2009 Hi, i have 245/35 on the front and 275/30 on the rear, i just picked the same sizes that were on the 18's at the time of buying the 19's. I think the front profile would be better as 30 like the rear but theres not much in it size wise. Spent too much money to go back to 18's mate and they did look a bit puny when they were on. A friend who runs his own garage reckoned putting standard suspension back on the front should cure the prob. Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 15, 2009 Share Posted December 15, 2009 Profile sizes are right for 19" wheels, but I still personally would just stick some 18" wheels on rather than trying to "fix" it by putting mismatched suspension on. Quote Link to comment Share on other sites More sharing options...
Guest BlackVelvetGuns Posted December 15, 2009 Share Posted December 15, 2009 i think i might of mislead you on the suspension, the rear suspension is still standard i think. So at the mo it would be mismatched with the non standard gear on the front? Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 26, 2009 Share Posted December 26, 2009 (edited) I have 19's on my car with Eibach lowering springs with new o/e shocks and dont get any problems with the wheel hitting the arch. I tend to avoid any holes in the rd though £200 for a pair of second hand dampers and springs is taking the p in my opinion, new dampers from Toyota are approx £100 each, new set of Eibach springs is around £200 Edited December 26, 2009 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Abz Posted December 26, 2009 Share Posted December 26, 2009 You don't really want to be going lower than a side profile of 35 on the front. This will effect your handling as you won't have a strong enough sidewall. With regards to potholes I avoid them like the plague with I am on the road an I have 17's with stock tyre sizes. I'd take DNK's approach, also get a geo done to make sure the 19's are sitting correctly. Quote Link to comment Share on other sites More sharing options...
