Series 2 volt metre to boost gauge
Guest livingthedeadbe
hello everyone,
i have a question i thought i might ask you all as i am unable to find this answer on the usa forums.
Now i have a Series 2 Sz-R which i have put a tt motor in. Everything is fine but as you know the Sz-Rs came with the Volt metre in the tri cluster and in the TTs it came with the Factory boost gauge.
Now, I have purchased the Whole TT cluster (speedo, tacho & tri cluster with boost gauge). How (if possible) could i wire this up to get the boost gauge functional with out having to replace the whole dash harness with a TT harness.
Does this make Any sence!?
Ben
i already have a hks boost gauge in place where the ac vent is (next to the clock), but i just want to know if its possible...im fussy about things like this
Thought that might be the case. :D Can't help I'm afraid but give it a couple hours 'til the tech guys wake up and you'll have the answer. :)
Happy Christmas mate. :)
yes you can, I have the info here somewhere, i was gonna do it with mine but i just refitted the voltmeter and fitted a greddy gauge in the heater thingy.. Least then you have two seperate gauges.. The normal gauge is rubbish anyway lol
give me a day or so..
Are you using the pre VVTI or VVTI 2jz?
  • 2 weeks later...
