Jellybean Posted December 14, 2009 Share Posted December 14, 2009 Didnt see anybody fitting buckets with stock seat belt, how do you retain the seat belt buckle, it is attached to the OEM seat frame Is it possible to fit these seats All I need is? Recaro Side Mounts Recaro rails Quote Link to comment Share on other sites More sharing options...
miko_supra Posted December 14, 2009 Share Posted December 14, 2009 Didnt see anybody fitting buckets with stock seat belt, how do you retain the seat belt buckle, it is attached to the OEM seat frame Is it possible to fit these seats All I need is? Recaro Side Mounts Recaro rails http://i64.photobucket.com/albums/h188/cheffboyrp/New%20Years%20Weekend%20Photoshoot/DSC_0005.jpg Is there not a mounting point on the seat for the buckle? If it falls short make a steel strap to extend the buckel. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 14, 2009 Author Share Posted December 14, 2009 Is there not a mounting point on the seat for the buckle? If it falls short make a steel strap to extend the buckel. I didnt buy the seats yet, not too sure if they will fit. Not too sure about a mounting point on the seat for the buckle Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted December 15, 2009 Share Posted December 15, 2009 Just need old school corolla ones or the like that bolt to the floor. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 15, 2009 Author Share Posted December 15, 2009 how does it work with Recaro Side Mounts, can you get Bride rails and bolt them to the side mounts I taught you bolt the seat via points on the side to the side mounts and she is fixed but from what I gather you can get recaro rails too(side mounts & rials ) and have an adjustable seat (back and forwards) Just confused how the Seat bolts to the side mounts and the rails too?Does the seat also have bolt positions on the bottom as well as the side? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted December 15, 2009 Share Posted December 15, 2009 Dunno, my recaros have mounting holes on the bottom. These may be different. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 15, 2009 Author Share Posted December 15, 2009 (edited) Dunno, my recaros have mounting holes on the bottom. These may be different. Do you also use the side mounts and Rails or just the rails because you can get both as an option, just not sure if you need both For example Side mounts for a fixed position and the Rails for an adjustable seat I think I got it but not too sure why you can buy runners, according to this side mount seats are fixed http://www.sportseats4u.co.uk/side-mounts-explained-s-37.html Next Q -- Are side mounts a direct bolt in , no holes required to drill Edited December 15, 2009 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
