n/a auto dials will they fit turbo
sparkyspar
Is it pre-facelift? The facelifts have 5 dials and the prefacelifts have 4. In answer to you're question then yes they will, as long as you are fitting prefacelift to prefacelift, and not prefacelift to facelift. Sorry i didn't get back to you're pm the other day, i'm afraid the amount if offered is as far as i can go....
They will fit but I always thought the rev counter wouldn't work properly as the TT and NA use differant singles. I had TT clocks in my NA for a while and the rev counter had a mind of its own. You have to use TT clocks when doing an NA-TT conversion dont you?
hi dont know if this the right thread/forum but have a quick question..
will a set of n/a auto dials fit a turbo auto face mkiv
i.e is there any other indictators on the turbo faces that are not on the auto??:blink:
I'm not sure about compatibility, but the facelift N/A has a Dial for 'voltage', whereas the facelift TT has a dial for ‘boost’ (although it’s pretty rubbish and just gives a positive and negative reading fundamentally)
