Guest blueangel Posted December 13, 2009 Share Posted December 13, 2009 On a bit of a downer today, with the bad weather setting in i had worries that the project was gonna fall apart.Good news i found a mate had a great unit which i could use to finish the car in and for free so all was good. Now after relocating my battery i was supposed to be getting the bodywork finished but today my compressor has decieded to die[sAD][/sAD]its only just over a year old. Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 13, 2009 Share Posted December 13, 2009 Whats actually happened to it? There is not alot really to go wrong. Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 13, 2009 Share Posted December 13, 2009 It wont turn over the fan spins then it just cuts the reset button out. Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 13, 2009 Share Posted December 13, 2009 Is it still under pressure? or does it do it when empty. Mine does this every now and then. I let the pressure go and turn it over by hand then reset it and its good for ages after that. Mind you my compressor is getting tired now, is yours belt driven? Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 13, 2009 Share Posted December 13, 2009 Its a 150ltr belt driven 3 hp sip airmate fella Its under pressure but only just its not a full tank and the fan is in a guard Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 13, 2009 Share Posted December 13, 2009 Sounds the same as mine. You can turn the motor part by hand there is a flat for a spanner. Sounds like the same prob I have. release the pressure and turn it over a few times by hand then reset the switch. I have come to the conclusion I have a dead spot in the windings and every so often the motor stops on that point, its like roulette LOL Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 14, 2009 Share Posted December 14, 2009 Rang SIP this morning and to honest they were very helpfull said basically the same turn it over by hand. They said also that running it on an exstention lead wouldnt help said it might lead to a drop in current and the cold air doesnt help either. Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 14, 2009 Share Posted December 14, 2009 You really need a 30amp tripped supply. hope it works. Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 14, 2009 Share Posted December 14, 2009 All good took the exstention out of the equation and it fired and turned over straight away.whew Quote Link to comment Share on other sites More sharing options...
