how is this done
gaz1
You will end up with a number that is a multiple of 9. Notice how the multiples of 9 have all the same object associated with them! The others are just put there as "noise" to fool you.
Let x be the tens of units you pick, and y be the single-digit units. E.g. if you pick 25 as a starting number, x=2 and y=5.
Your starting number is 10x+y.
Now minus each digit to get your final number: 10x+y - x - y
= 9x
x must be an integer greater than 0 (otherwise your starting number would only be 1 digit, which breaks the rules) and less than 10, so your final number will always be a multiple of 9. Simples :)
