Cams>>Gt4082jb
Rinus
Funny,
was just reading about solaris-ecu...
People seems very happy with these.
Ok no adjustable cam pulleys!
And I'm looking for 550hp for sure-600hp max
and a bit end power...
Will contact Ryan when I'm ready,
will put some project pics and I will take the time,
so I hope you guys have patience with me ;)
  • Replies 51
Not being controversial, but if the budget will stretch to adjustable pulleys you might as well get them. It'll be VERY annoying to check cam timing, find it's out, and have no means of resetting it. 2JZ engines with un skimmed heads and blocks and stock, or HKS and JUN cams usually time up on stock pulleys to within a couple of degrees either way. Skyline RB26's on the other hand can be a mile out. On a new block and head I had to shift the timing at least 6 crank degrees to get the timing right. Get steel ones if you can, a lot of aftermarket alloy ones, especially bright coloured wheels, are so soft that tooth wear is a big problem after a while.
