Cams>>Gt4082jb
Rinus
Like to know if anyone has an idea witch cams on this setup would be best;
-Turbonetics cast-manifold
-GT4082jb
-Sard drop-in 650cc
-Aem standalone ecu
-walbro 255
-oem flywheel-with rps-steet kit
*going for 550hp on the flywheel (but never more then 600hp)
thinking of the 264-264cams or isn't this the best choice with the cast-mani...
And a good place to get cams,
like the hks ones but the price a little bit less:innocent:
Any other good brands?
Thank you
  • Replies 51
Im running stock Jspec cams. T67 DBB ran 534 bhp last weekend at SRR. If i want any more power at a later date then ill be putting cams in it but Im happy with the power output at the miunte :)
Looking at your spec though if you have not already bought the clutch/flywheel Id have a look arround at other options, I hate my RPS its crap. Although I am running the 6 puck
@ m5w,
got the clutch already mounted...
with streetdisc though and all the other stuff new from the dealer incl.flywheel,
really fine clutch I think, had little problems with engagement,
but have put 5speed slave cilinder on it and now its ok...
@ m5w,
Hope your happy with it. Mine is just grabby and it really annoys me. Its quite stiff too and nothing compaired to the southbend that I tried in Rob Wilds car.
All of the above is on the road though. On the track its excellent and you can give it all the abuse you like and it just takes it :)
@ m5w,
Street disc is great, my rps has took a shed load of abuse and is still perfect, quiet and light to use, great clutch.
Jamie, is 650cc a good choice then?
If I buy 800cc, it's the same money...
(you'll never now for the future)
If on emanage id stay 650's, Aem or solaris etc id go with 800's
Edited by JamieP (see edit history)
Future proof it with slightly larger injectors. Saying that Injectors depend on the manufacturer. What make were you thinking of going with? for example i think the seimens are know to stick.
I should have gone with the street and stock flywheel. I just did not need the lightweight fly and 6 puck. The price was the selling point though :D
Ok will first choose ecu, then injector...
I saw the sard drop inns don't need a resistor pack...
believe the uk's do need one.
Do I also need to remove the fuel pulsation demper??
The first thing you need to do is choose your mapper, Thats the most important thing :) Then speak to them about the spec your thinking of and see what they recommend.
If your looking for 500-550 bhp then you dont need to remove the damper, Any more than that and it becomes a restriction.
