Guest jap nut Posted December 12, 2009 Share Posted December 12, 2009 Having problems with no second turbo so put in in TTC to see if its one of the vsv valves and now it makes no boost at all?Can anyone suggest what to try next or is my second turbo fucked?there are no strange noises and the car runs great just no second.any help would be greatly appreciated.thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted December 12, 2009 Share Posted December 12, 2009 Sounds a bit dodgy bud. If you have no turbine left in your 2nd turbo the 1st one won't make any boost in TTC as the actuator is open allowing all the boost made go straight past the 2nd tubby and out through the exhaust. That was the main symptom for me when my 2nd tubby was fooked. I was still getting boost from the 1st turbo when in normal mode, nothing in TTC. Quote Link to comment Share on other sites More sharing options...
Guest jap nut Posted December 12, 2009 Share Posted December 12, 2009 Sounds a bit dodgy bud. If you have no turbine left in your 2nd turbo the 1st one won't make any boost in TTC as the actuator is open allowing all the boost made go straight past the 2nd tubby and out through the exhaust. That was the main symptom for me when my 2nd tubby was fooked. I was still getting boost from the 1st turbo when in normal mode, nothing in TTC. Thanks was thinking that just needed someone in the know to tell me.looks like it search for a set of turbos time[sAD][/sAD] if anyone has a set can they send me a pm Thanks. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 13, 2009 Share Posted December 13, 2009 Are you getting any strange noises coming off boost when you have it in the regular sequential mode? Quote Link to comment Share on other sites More sharing options...
Nic Posted December 13, 2009 Share Posted December 13, 2009 Sounds like the 2nd turbo has blown Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted December 13, 2009 Share Posted December 13, 2009 time to go single http://www.mkivsupra.net/vbb/showthread.php?t=203314 Quote Link to comment Share on other sites More sharing options...
Guest jap nut Posted December 13, 2009 Share Posted December 13, 2009 Are you getting any strange noises coming off boost when you have it in the regular sequential mode? It Kind of makes a a noise' now don't laugh like a whoopy cushion:taped: does this make any sense,Thing is i thought by going TTC it bypasses everything?Thanks Scott. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 13, 2009 Share Posted December 13, 2009 It Kind of makes a a noise' now don't laugh like a whoopy cushion:taped: does this make any sense,Thing is i thought by going TTC it bypasses everything?Thanks Scott. Yup thats exactly what mine did. As soon as I came off boost it was like a woosh with a brap inside it lol. 2nd tubby is toast. Going TTC opens up the actuators. This means that rather than sequentailly operating both turbo's spool up at the same time. The exhaust, when working correctly, spins through the turbines of both turbo's spooling them up. As your 2nd turbo is fooked and doesn't have a 2nd turbine the exhaust gas is just taking the easiest way out and completely avoiding the 1st turbo all together. The 1st tubby may spool up a tiny little bit, due to the slight resistance for all the exhaust gas to exit through the 2nd turbine, but you won't see much pressure at all (1 or 2 psi). The trouble is it is very often the 2nd turbo that goes, even though the 1st one takes the most use in normal operation. Most often you have to buy the turbo's as an assembly and can't go down the cheap option of just buying the 1. Good luck to you anyway. Quote Link to comment Share on other sites More sharing options...
Guest jap nut Posted December 13, 2009 Share Posted December 13, 2009 (edited) Yup thats exactly what mine did. As soon as I came off boost it was like a woosh with a brap inside it lol. 2nd tubby is toast. Going TTC opens up the actuators. This means that rather than sequentailly operating both turbo's spool up at the same time. The exhaust, when working correctly, spins through the turbines of both turbo's spooling them up. As your 2nd turbo is fooked and doesn't have a 2nd turbine the exhaust gas is just taking the easiest way out and completely avoiding the 1st turbo all together. The 1st tubby may spool up a tiny little bit, due to the slight resistance for all the exhaust gas to exit through the 2nd turbine, but you won't see much pressure at all (1 or 2 psi). The trouble is it is very often the 2nd turbo that goes, even though the 1st one takes the most use in normal operation. Most often you have to buy the turbo's as an assembly and can't go down the cheap option of just buying the 1. Good luck to you anyway. Thanks for that,if ya hear of any turbos for sale over there ya might send me a pm as i can't post a wanted post on here /vbb/images/smilies/bbcode_sad.gif .thanks for your info Scott much appreciated. Edited December 13, 2009 by jap nut spelling (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted December 13, 2009 Share Posted December 13, 2009 I would recommend you spend the tenner and join up to the site mate. It will be worth it 100 times over in the long run bud. It's a tenner, the forum has already saved you 10 times that on diagnosis costs. Quote Link to comment Share on other sites More sharing options...
