Nugget Posted November 9, 2002 Share Posted November 9, 2002 Am looking for new brembo brakes for my mkiv, any ideas on the best place to get them? Thanks Nug Quote Link to comment Share on other sites More sharing options...
Terminator Posted November 9, 2002 Share Posted November 9, 2002 Are you doing this for performance or looks? Quote Link to comment Share on other sites More sharing options...
Nugget Posted November 9, 2002 Author Share Posted November 9, 2002 To be honest, a bit of both! I need new brake pads, so was kind of thinking I might upgrade the brakes at the same time! The car is an import with standard brakes, so any ideas? Quote Link to comment Share on other sites More sharing options...
Alex Posted November 9, 2002 Share Posted November 9, 2002 Don't get the drilled rotors...get grooved rotors. the drilled ones are prone to cracking. You'll need a wheel with a big offset (+50 or there abouts) Not sure who stocks them, sorry. Quote Link to comment Share on other sites More sharing options...
Steve W Posted November 9, 2002 Share Posted November 9, 2002 Sorry to butt in... Will the std' 17's take most after-market brake uprgrades ? If I ever want to 'UP' from the small-Jap set-up I may want to go straight to something 'lairy' - if I'm gonna spend loads for UK brakes might as well go further ! ? (probably not a lot dearer) FatS. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 9, 2002 Share Posted November 9, 2002 there is a very small gap between the uk spec calipers and the 17" wheels... the diameter is also a problem on 355mm brembo's!!! Quote Link to comment Share on other sites More sharing options...
Steve W Posted November 9, 2002 Share Posted November 9, 2002 SO, only 'normal' aftermarkets.....nothing TOO silly-size ? (I probably wouldn't want {couldn't afford!} extra large ones anyhow) Quote Link to comment Share on other sites More sharing options...
Terminator Posted November 9, 2002 Share Posted November 9, 2002 Unless you are going to fit larger rotors than the UKspecs, there is not much in it in performance terms. Martin did or found some calculations that showed UK and six pot fronts to be equal in stopping power. UK's are cheaper than six pots especially if you can get in on a group buy. If you go bigger brakes you will need big wheels as very few imports on stock Jap brakes will have aftermarket wheels big enough to fit over bigger up rated rotors and callipers. As for other wheels and brake set ups you need to ask around the BBS to see which wheel fits over which calliper. You can get a significant increase in braking performance just but upgrading the Jap fronts to UK. Quote Link to comment Share on other sites More sharing options...
Steve W Posted November 9, 2002 Share Posted November 9, 2002 Cheers Phil & Alex.... [sorry Nugget - feel free to continue YOUR thread:eek: ] [bargin'-in happens a lot on here - and I do most OF IT !] [sorry, AGAIN] Quote Link to comment Share on other sites More sharing options...
