trinitom Posted December 11, 2009 Share Posted December 11, 2009 I think i may have a sticking exhaust valve, lots of white smoke with a nice fuel smell and a small tapping noise too. is this common to happen? any solutions? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted December 11, 2009 Share Posted December 11, 2009 If the seals are shot take the head off, get it stripped/chemically cleaned & rebuilt otherwise it will just get worse. Quote Link to comment Share on other sites More sharing options...
trinitom Posted December 11, 2009 Author Share Posted December 11, 2009 If the seals are shot take the head off, get it stripped/chemically cleaned & rebuilt otherwise it will just get worse. no way!! i'm going in holidays next week (driving). must be another way to resolve this. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 11, 2009 Share Posted December 11, 2009 Only solution is repair. Head off, new parts and rebuild Quote Link to comment Share on other sites More sharing options...
hodge Posted December 11, 2009 Share Posted December 11, 2009 I had the same problem with my blue Supra. It was a little more severe as I had 4 sticking. It turned out the oil pump was worn and wasnt supplying the head with enough oil and the when the engine warmed the buckets were tightened inside the head jamming the valves. I dont want to to scare you at all but its something id look at. remove the cam covers when the cars cold and check to see if the buckets are free and not stuck in at all. My guess is its gona be 1 of the valves at the back of the engine near the bulkhead. Either way though mate as Rob says the head has to come off. Fingers crossed not the engine out though. Do you have an oil pressure gauge fitted if so what sort of pressure are you seeing. Quote Link to comment Share on other sites More sharing options...
trinitom Posted December 11, 2009 Author Share Posted December 11, 2009 I had the same problem with my blue Supra. It was a little more severe as I had 4 sticking. It turned out the oil pump was worn and wasnt supplying the head with enough oil and the when the engine warmed the buckets were tightened inside the head jamming the valves. I dont want to to scare you at all but its something id look at. remove the cam covers when the cars cold and check to see if the buckets are free and not stuck in at all. My guess is its gona be 1 of the valves at the back of the engine near the bulkhead. Either way though mate as Rob says the head has to come off. Fingers crossed not the engine out though. Do you have an oil pressure gauge fitted if so what sort of pressure are you seeing. i'm seeing around 115/120 psi, and the tapping sound comes from 5/6 piston side. looks like i have to remove the cam cover and see! by the way the tapping it's very low and dificult to notice. Quote Link to comment Share on other sites More sharing options...
hodge Posted December 11, 2009 Share Posted December 11, 2009 I hope its ok for you mate. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
trinitom Posted December 12, 2009 Author Share Posted December 12, 2009 I hope its ok for you mate. Fingers crossed. I hope so too, but this is maybe coming from my head! the car runs very nice, pulls strong, i think this is just my imagination. Anyway tomorrow I'm going to record and share with you guys and hope that everything is ok. Thanks for the help people.. Quote Link to comment Share on other sites More sharing options...
