Jellybean Posted December 11, 2009 Share Posted December 11, 2009 (edited) (Apexi AVCR at 1.0 bar 35 duty cycle, some gears duty cycle is adj +/- dependant on performance) When the temp outside here is close to freezing 0 , 1 degrees the car runs fantastic, but during normal air temps 5-10 degrees she coughs and splutters on the same settings on transition to the second turbo Any advice, should I run two settings dependant on air temp Edited December 11, 2009 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
