Dnk Posted December 11, 2009 Share Posted December 11, 2009 I had a new matrix fitted a few years ago with no problems but can only get it to blow luke warm air even on full hot on the dial, im pretty sure its not an airlock as i spent over an hour bleeding the system. Pipes going in and out of the matrix are hot. How can i check the other parts that control the temp are working or not working. Cheers Dunk Quote Link to comment Share on other sites More sharing options...
stevie_b Posted December 11, 2009 Share Posted December 11, 2009 Have you seen this thread? It may be worth checking the actuating arm as SteveC describes. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 11, 2009 Author Share Posted December 11, 2009 Thanks for that Steve thats most helpfull and i'll be having look sometime this morning, if its as simple as that then i'll be a very happy chap as i really dont want to have the dash out again. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 14, 2009 Author Share Posted December 14, 2009 Thats all working correctly on my car and ive also checked the other heater controls and their all working, spent 2 hours bleeding the system and now have luke warm air coming through the vents. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted December 14, 2009 Share Posted December 14, 2009 Hmm, I'm watching this thread with interest as I have very similar symptoms as the ones you describe. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 15, 2009 Author Share Posted December 15, 2009 Took the dash surrounds off and checked this part works which it seems to be Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted December 15, 2009 Share Posted December 15, 2009 Can you hear "things moving" when you adjust the temperature up and down? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted December 15, 2009 Share Posted December 15, 2009 When you switch it to hottest setting, are you sure it's pushing to the full extent of its travel, and not getting stuck halfway. In the passenger footwell, watch the actuator arm move as you adjust the dial to hot, then when it stops, see if it'll travel further with a bit of persuasion. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 15, 2009 Author Share Posted December 15, 2009 Can you hear "things moving" when you adjust the temperature up and down? You can see the actuators moving but as for the actual valve on the heater matrix i dont know, all the other flaps work properly and change on the heater control as they should. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 15, 2009 Author Share Posted December 15, 2009 When you switch it to hottest setting, are you sure it's pushing to the full extent of its travel, and not getting stuck halfway. In the passenger footwell, watch the actuator arm move as you adjust the dial to hot, then when it stops, see if it'll travel further with a bit of persuasion. That was the 1st thing we checked and again it looks like its working correctly. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted December 15, 2009 Share Posted December 15, 2009 Is your engine getting up to operating temperature (IE, your stat isn't stuck open?) Quote Link to comment Share on other sites More sharing options...
Nic Posted December 15, 2009 Share Posted December 15, 2009 There should be something in the troubleshooting section of the service manual here http://www.turbosupras.com/pages/en/pages/specifications/JZA80/a80tsrm.htm Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 15, 2009 Author Share Posted December 15, 2009 Is your engine getting up to operating temperature (IE, your stat isn't stuck open?) Engine warms up no problem and sits spot on the middle of the temp gauge like its always done since i bought it 10 yrs ago, the car had a new o/e radiator and o/e heater matrix fitted in 2006 and also not so long ago had a new o/e thermostat fitted. Theres no gurgleing noises in the dash and everything seems to work fine but only luke warm air when on full hot. Quote Link to comment Share on other sites More sharing options...
