Wiring up LED strip's are reverse light's
supraszr
I have recently brought some lights from the US for my girlfriends Del sol due to the way these were wired I had to come up with a different way of wiring in reverse lights.
I have brought those Audi style strips and put them on the rear as reverse lights which worked perfectly for a couple of days then they started coming on when just turing on the ignition? and when going into reverse they come on brighter. I presume this is due to a small amount of current going to them on ignition. Anyone any ideas on how to resolve this issue would be much appreciated.
It sounds like you have a Earth problem!
Try and re-wire them using a good bodywork earthing point,
This is the same as you see on the rear of cars sometimes when they brake and indicate and everything on one side lights up dimly.
I did think it may be an earth problem and have since tested it on the original negative wire and on several earth points on the car. I am a little confussed to say the least
