FullRace T4 exhaust manifold
vase
Since I'm planning on doing a twin turbo setup I have a slightly used Full Race exhaust manifold for sale. It is the Gen2 T4 item for Toyota Supra MKIVTT 2JZGTE engine. This is one of the best and most expensive exhaust manifolds availabe for supra. It has a divided T4 flange and it's made to use two tial wastegates so boost control is very accurate with this manifold.
I'm located in Finland and you can contact me with private message from this forum.
The price is £1100 and this includes the shipping charges to the UK so there will be no extra costs. And I will accept paypal of course.
http://www.vasmo.org/temp/supra/fullrace.jpg
Hi guys!
Yes it is a very nice piece indeed. For me this is the only single turbo manifold I would use because of the quality. Obviously it won't work with twin turbos though hehe :)
As mentioned it uses two tial 44mm wastegates and the boost control is very accurate - no boost creep whatsoever. You can run them with screamer pipes or routed into the dp like I did. It fits nicely and it's completely bolt-on.
Here are some pics of it installed to my supra:
http://www.vasmo.org/temp/supra/remppa2/remppa7.jpg
http://vasmo.org/temp/supra/remppa2/remppa8.jpg
And here is a pic of my wastegate routing (the simplest way of course is using screamer pipes):
http://vasmo.org/temp/supra/remppa2/remppa12.jpg
looks an interesting setup. The front 1 looks a bit of an awkward angle to work with, saying that you may aswel just twist it round and run a screamer from it.
Wouldnt twin 38mm tials work this manifold aswel?
Yes the 38mm tials should work also.
Hi guys!
Did you ever run this car in anger with that wastegate setup?
I don't really know what you mean but I drove so hard that my whole engine exploded. :D
It took almost 300kph in mile so it could be said it has gone with anger ;).
Someone will get a bargain with this manifold, buy it with confidence :).
Oh yeah - I think I remember the pics with the gaffa tape on the bell housing, was that you? :D
Did that front wastegate recirc pipe cause any problems with heat melting paint or anything? I ask because I haven't seen anyone recirc it before.
Yes that was me. I think I will remove the gaffa tape and get it fixed properly though. :D
There hasn't been any problems with the recirc pipes so it's a good solution if you don't like the screamer sound.
