Guest Carsten Posted December 10, 2009 Share Posted December 10, 2009 Hey guys, ive a wierd ticking noise on my engine. Located somewhere inside the engine itself. (Correct position shown in the video). http://www.youtube.com/watch?v=sKIOFbmze6A Could someone sort out what this is? greets Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 10, 2009 Share Posted December 10, 2009 it does not sound major, maybe crank pulley on way out.. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted December 13, 2009 Share Posted December 13, 2009 Thx Jurgen. Any more opinions? Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 15, 2009 Share Posted December 15, 2009 Look down the rear of the rad and see if the bottom pulley is wobbling. Certainly does not sound like anything inside the engine. Most likely belt/pulley related. Is the car running nonstandard ancillerey pulleys? Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted December 15, 2009 Share Posted December 15, 2009 im listened to the Vid now many times Regarding to the very low idle i would asume by the rytm that the ticking noise is coming from a valve , but i can be wrong, does it become worse or better when engine gets warm how does it sound if you raise the rpms a bit eaxmple to 1000 and 2000? Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted December 15, 2009 Share Posted December 15, 2009 or is it rorr rorr sound that you are wondering about ? Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted December 16, 2009 Share Posted December 16, 2009 im listened to the Vid now many times Regarding to the very low idle i would asume by the rytm that the ticking noise is coming from a valve , but i can be wrong, does it become worse or better when engine gets warm how does it sound if you raise the rpms a bit eaxmple to 1000 and 2000? The low idle is caused by a not cleaned ICV. I´ve to do that next week. Worse or better is a good question ^^ Well if the car is warm and i drive hard it gets a bit worse. And yes: Higher rpms = faster/bit louder noise. Wen to a garage yesterday, the suggested that it could be a hydraulic valve lifter. But it is nothing serious. @Terminator Car is bone Stock regarding to engine driveshaft etc. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 16, 2009 Share Posted December 16, 2009 Wen to a garage yesterday, the suggested that it could be a hydraulic valve lifter. But it is nothing serious. I,m afraid your garage doesn't know the Supra engine, as it runs solid lifters not hydraulic, i guess it could be a worn cam lobe or shim, but it could also be a stuck or bent valve. Have you checked your compression? does it misfire at all? Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted December 16, 2009 Share Posted December 16, 2009 (edited) There may be little missfire right before the gearchange when i floor it. Haven´t done a compression test yet. As long as it isnt something serious its okay. ps: I´ll do another Video while driving. Edited December 16, 2009 by Carsten (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted December 16, 2009 Share Posted December 16, 2009 as Tricky said , go to the garage and have them to check the compression, a bent valve or worn cam lobe(s) can go hand in hand with low idle also , where in Germany are you located? in Köln i know a guy that is very good in supras Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted December 16, 2009 Share Posted December 16, 2009 as Tricky said , go to the garage and have them to check the compression, a bent valve or worn cam lobe(s) can go hand in hand with low idle also , where in Germany are you located? in Köln i know a guy that is very good in supras Near Frankfurt. Quite a distance to Köln Checking compression today. Will let you know. Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 16, 2009 Share Posted December 16, 2009 What idle speed do you get at tick over? Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted December 16, 2009 Share Posted December 16, 2009 Let me test this tomorrow. Got my car back for oil change etc. Everything fine till now. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted February 3, 2010 Share Posted February 3, 2010 Have to bring this up again. Ive done a compression Test. All cylinders were fine except Nr2. Showed a compression of only 7 Bar +-100psi. What should i do next? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted February 3, 2010 Share Posted February 3, 2010 Have to bring this up again. Ive done a compression Test. All cylinders were fine except Nr2. Showed a compression of only 7 Bar +-100psi. What should i do next? A leak down test to see where the pressure is being lost. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted February 3, 2010 Share Posted February 3, 2010 Little add: Got huge loads of white smoke on cold startup. If the engine/exhaust is warm the smoke disappears. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted February 3, 2010 Share Posted February 3, 2010 Little add: Got huge loads of white smoke on cold startup. If the engine/exhaust is warm the smoke disappears. this sounds normal Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 3, 2010 Share Posted February 3, 2010 this sounds normal Not if it's loads and loads. Compression may be down due to a HG leak into the water system, and that causes the white smoke. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted February 4, 2010 Share Posted February 4, 2010 Yes, the exhaust smells like antifreeze Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted February 4, 2010 Share Posted February 4, 2010 I think you've answered your own question then mate. Blown HG Quote Link to comment Share on other sites More sharing options...
