Guest lex Posted December 9, 2009 Share Posted December 9, 2009 hi all i have read about this all over the net and my question is where is no1 speed sensor in the dash board i know no2 is on the gearbox i found diagrams which say speed sensor no1 combination meter v10 .now this is where i get confused to where it is .is it the odometer with the trip or is it the speedo it self or am i looking for a box somewhere in the dash ,as i have this code 42 the car has no converter on it and it clocks up in km and my speedo has a 115 dail face on and is limited .so could you fine people help me in finding this no.1 speed sensor Quote Link to comment Share on other sites More sharing options...
merckx Posted December 10, 2009 Share Posted December 10, 2009 (edited) Both sensors are on the gearbox, I'm not 100% sure if the auto gearbox car has 2 sensors and the manual 1. Sensor locations, (the files take a few seconds to open). http://www.turbosupras.com/pdfs/JZA80%20TSRM/DI.pdf#page=413 Also http://www.turbosupras.com/pdfs/JZA80%20TSRM/DI.pdf#page=249 I would be looking for a bad connection at the sensors, multiplug connectors at the speedo and the ecu. Unplugging them and making sure they plug in okay and make a good connection. With the pdf files above, at the top you can search for specific words like "speed sensor" , click find next and it will take you right through the manual where it's found the words you searched for. Do a search in the diagnostics section in the main manual below, I've just started searching like this, it's a very useful function as the workshop manual is absolutely huge. http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm Edited December 10, 2009 by merckx (see edit history) Quote Link to comment Share on other sites More sharing options...
merckx Posted December 10, 2009 Share Posted December 10, 2009 (edited) double post Edited December 10, 2009 by merckx (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest lex Posted December 10, 2009 Share Posted December 10, 2009 Both sensors are on the gearbox, I'm not 100% sure if the auto gearbox car has 2 sensors and the manual 1. Sensor locations, (the files take a few seconds to open). http://www.turbosupras.com/pdfs/JZA80%20TSRM/DI.pdf#page=413 Also http://www.turbosupras.com/pdfs/JZA80%20TSRM/DI.pdf#page=249 I would be looking for a bad connection at the sensors, multiplug connectors at the speedo and the ecu. Unplugging them and making sure they plug in okay and make a good connection. With the pdf files above, at the top you can search for specific words like "speed sensor" , click find next and it will take you right through the manual where it's found the words you searched for. Do a search in the diagnostics section in the main manual below, I've just started searching like this, it's a very useful function as the workshop manual is absolutely huge. http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm thanks for the links mine is a manual and i think it only has one speed sensor on the box im looking for the one some where in the dash between the odometer and the speedo but il have alook through the links to see if shows me anything .thanks again Quote Link to comment Share on other sites More sharing options...
Guest lex Posted December 17, 2009 Share Posted December 17, 2009 yea fixed it no more error code 42[GRIN][/GRIN] odometer at fault so i cut pink output wire and linked it to the blue/red input wire Quote Link to comment Share on other sites More sharing options...
supra-spain Posted January 10, 2010 Share Posted January 10, 2010 yea fixed it no more error code 42[GRIN][/GRIN] odometer at fault so i cut pink output wire and linked it to the blue/red input wire good information, I have the same problem is solved by disconnecting odometer? Quote Link to comment Share on other sites More sharing options...
Dave Posted January 10, 2010 Share Posted January 10, 2010 yea fixed it no more error code 42[GRIN][/GRIN] odometer at fault so i cut pink output wire and linked it to the blue/red input wire thats how i fixed mine Quote Link to comment Share on other sites More sharing options...
supra-spain Posted January 17, 2010 Share Posted January 17, 2010 (edited) yea fixed it no more error code 42[GRIN][/GRIN] odometer at fault so i cut pink output wire and linked it to the blue/red input wire which is the cable I have to join, thanks Edited January 17, 2010 by supra-spain (see edit history) Quote Link to comment Share on other sites More sharing options...
supra-spain Posted January 17, 2010 Share Posted January 17, 2010 (edited) http://img12.imageshack.us/img12/3051/odometrox.png Edited January 17, 2010 by supra-spain new pic (see edit history) Quote Link to comment Share on other sites More sharing options...
