optim8 Posted December 9, 2009 Share Posted December 9, 2009 Evening All, Took my Supra to work today (lots of big grins and disapearances in my rear view!) Anyway when leaving to come home, it's dark of course so on goes my lights. So my question here is what should light up within the car? For me I get Dash clock lights, heater matrix buttons, heater fan speed and cig lighter. I sort of feel I'm missing, my autoshifter and perhaps heater temperature dial. Any insight much appreciated. Lovin the Xmas Theme by the way!!! Link to comment Share on other sites More sharing options...
AndyT Posted December 9, 2009 Share Posted December 9, 2009 (edited) Driver electric window switch. Autoshifter should light up. No lights in the temperature control. Well mine doesn't anyway. Footwell lights? Perhaps with the courtesy lights when a door is opened. Not sure. Edited December 9, 2009 by AndyT (see edit history) Link to comment Share on other sites More sharing options...
Benyon Posted December 9, 2009 Share Posted December 9, 2009 Im pretty sure all the buttons should light up and footwells also check lights on & for the door so people to see when they are open , you mentioned the rest I think thats it. Oh check the bunny hop button too. Link to comment Share on other sites More sharing options...
mawby Posted December 9, 2009 Share Posted December 9, 2009 Foot well lights only when a door is open, and it was an optional extra. (Or at least not present on all models) Link to comment Share on other sites More sharing options...
Chewie Posted December 9, 2009 Share Posted December 9, 2009 I could've sworn blind that the heater temp light use to be on. Bizarrely I only noticed there wasn't one only last week. I've owned my Supe for 8 yrs! Link to comment Share on other sites More sharing options...
optim8 Posted December 9, 2009 Author Share Posted December 9, 2009 Thanks all, guess I'm missing a couple then, Footwell Courtesy lights are working fine too, forgot to mention that. Bunny Hop Button? Sounds great, Where do I get one? Want a 'Supra Pursuit' button as well but perhaps going BPU at some point might help that one!!! Link to comment Share on other sites More sharing options...
Chewie Posted December 9, 2009 Share Posted December 9, 2009 Oh yeah, I forgot to mention the water temp gauge brightness can fade to a faint glow while all the other gauges are bright. It's just one of those things you have to put up with with a 15 yr old car. Link to comment Share on other sites More sharing options...
Suprab1 Posted December 10, 2009 Share Posted December 10, 2009 I could've sworn blind that the heater temp light use to be on. Bizarrely I only noticed there wasn't one only last week. I've owned my Supe for 8 yrs! This light works on mine. Just replaced the bulb about 3 month ago. Had to order it from toyota (little green bulb) couldn't get from any motor factors. Link to comment Share on other sites More sharing options...
stevie_b Posted December 10, 2009 Share Posted December 10, 2009 No lights in the temperature control. Well mine doesn't anyway. Same here Andy: it seems strange that they didn't stick a bulb behind the heater dial/knob. This light works on mine. Just replaced the bulb about 3 month ago. Had to order it from toyota (little green bulb) couldn't get from any motor factors. Are you talking about the heater dial? From the text you quoted, it sounds like you are. If so, strange that your car has one whilst a lot of others don't. Surely that wasn't an optional extra... Link to comment Share on other sites More sharing options...
Chewie Posted December 10, 2009 Share Posted December 10, 2009 This light works on mine. Just replaced the bulb about 3 month ago. Had to order it from toyota (little green bulb) couldn't get from any motor factors. And I suppose you had to rip out the dash just replace this bulb. Link to comment Share on other sites More sharing options...
Suprab1 Posted December 10, 2009 Share Posted December 10, 2009 Just checked there to be sure. Its the heater knob with 20-25-30 on it and lights up perfect. just unclip the dash panel and you'll find it handy. I replaced both heater temp & control you need long nose plyers for 1 or both can't remember. Link to comment Share on other sites More sharing options...
stevie_b Posted December 10, 2009 Share Posted December 10, 2009 Ah, maybe I was getting confused. IIRC the knob doesn't light up. Hence you can see the numbers like you said, but not the actual setting. Link to comment Share on other sites More sharing options...
Suprab1 Posted December 10, 2009 Share Posted December 10, 2009 Yes the numbers light but there is also a line on the knob that lights so you can see your setting Link to comment Share on other sites More sharing options...
jackso11 Posted December 10, 2009 Share Posted December 10, 2009 The temp and fan speed light up sometimes on mine, most of the time it doesn't work. On my last supra it never lit up. Guess maybe the connection is a bit crap after 10-15 years, when I do the blue dash conversion over xmas that will sort it out. Link to comment Share on other sites More sharing options...
fizzle Posted December 10, 2009 Share Posted December 10, 2009 ashtray should light when opened as well Link to comment Share on other sites More sharing options...
Chewie Posted December 10, 2009 Share Posted December 10, 2009 Only noticed a few months ago that the door lock surround lights up when I press the key fob. I never got round to cleaning it. Link to comment Share on other sites More sharing options...
