TT Paul Posted December 7, 2009 Share Posted December 7, 2009 got emanage fitted with 650 injectors partly mapped. would the mines ecu be a better choice jspec tt auto..??? Quote Link to comment Share on other sites More sharing options...
heckler Posted December 7, 2009 Share Posted December 7, 2009 got emanage fitted with 650 injectors partly mapped. would the mines ecu be a better choice jspec tt auto..??? is the mines ECU just a reprogrammed stock ECU? if it is i doubt it could handle 650's! Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 7, 2009 Author Share Posted December 7, 2009 it is a reprogrammed ecu not sure on the size of injectors it takes Quote Link to comment Share on other sites More sharing options...
heckler Posted December 7, 2009 Share Posted December 7, 2009 it is a reprogrammed ecu not sure on the size of injectors it takes well. from my experiance, reprogrammed ECU maps are based on the existing setup, so it can handle 440/550's (as a guess it'll be setup for 440's) Given the option, i'd keep the EMU... Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted December 7, 2009 Share Posted December 7, 2009 You cant remap a Mines to suit I'm afraid. So its Emanage I'm afraid. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 7, 2009 Share Posted December 7, 2009 You're far better off with the EMU, it has far more scope for future upgrades, and properly mapped it will also be better. Why are you running 650cc injectors? are you running a single turbo? Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 8, 2009 Author Share Posted December 8, 2009 650 fitted on recomendation so here they are Quote Link to comment Share on other sites More sharing options...
Alex Posted December 8, 2009 Share Posted December 8, 2009 MINES ECU is for stock setup only. And as far as I'm aware Manual's only too. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted December 8, 2009 Share Posted December 8, 2009 MINES ECU is for stock setup only. And as far as I'm aware Manual's only too. I've got an Auto MINES ECU Running it on a manual though & it works fine Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 8, 2009 Share Posted December 8, 2009 650 fitted on recomendation so here they are So are you running hybrids or something? unless you are, the 650cc injectors are pointless. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 8, 2009 Author Share Posted December 8, 2009 not running hybrids so from what your saying wont get much from them' im fully bpu just after 400bhp last run before emy fitted was 363bhp now its 346bhp as no manu mode ryang could not tune it Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 8, 2009 Share Posted December 8, 2009 650cc injectors are way too big for BPU, i would Imagen that your not going to get the best from the motor with over spec'd injectors as with smaller pulse width/duty cycle that you're ultimately going to get, You will see less adequate atomisation, i am only running 540cc with a single turbo, admittedly they flow a fair bit more, but i'm limited to just over 500BHP. Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 8, 2009 Share Posted December 8, 2009 You will see less adequate atomisation I'm not convinced about that, once they are spraying they are atomising as good as they'll get. 650's are a waste of capacity for BPU but they'll run the car just fine, otherwise idling and low speed tootling would be affected on all Supras that run them (or bigger). With 800+cc you might start getting problems due to the pulse width being too short under the light loads and the injectors behaving erratically. But yeah, I wouldn't have fitted 650s just for BPU. -Ian Quote Link to comment Share on other sites More sharing options...
TT Paul Posted December 9, 2009 Author Share Posted December 9, 2009 looks like might be some work to do ie rethink Quote Link to comment Share on other sites More sharing options...
